Old 01-22-2014, 08:48 PM   #43
WarWolfX0
WarWolfX0's Avatar
Drives: 2010 Chevy Camaro 2SS/RS 1LE Manual
I would be ripping my car apart if it was at least 40F not the 9F it is now
40F is shorts weather in Chicago
Since i have a 2010 i heard that there might be a chance that i might have 2 coax wire going to the onstar
like in this item
http://www.ebay.com/itm/BLUETOOTH-ON...48256a&vxp=mtr
when i look at it i seem like that bluetooth piece is just a antenna covering a coax plug.
not sure it it will work but i would like to upgrade the onstar to a newer one, i think the new one have bluetooth in the mylink radio now.
WarWolfX0 is offline   Reply With Quote
Old 01-22-2014, 08:56 PM   #44
DWALEX
DWALEX's Avatar
Drives: Currently 2016-2SS, Future ZL1/Z28
like in this item
If you upgrade to mylink you don't need a onstar with BT
DWALEX is offline   Reply With Quote
Old 01-22-2014, 09:13 PM   #45
Toasty
Custom User Title :D
Toasty's Avatar
Drives: 2011 Summit White 2LT/RS
Originally Posted by 2SSRS@Gen5diy View Post
Its bad here right now too, its 75 and mostly sunny.
Please send this warmer weather with my Mylink Nav kit. Thanks!
like in this item
Everything that I have seen indicates that you have the old style sharkfin antenna with separate onstar/gps coax lines, and you will need to update that to the newer 2011-up with shared onstar/gps coax. The bluetooth does seem to be in the new mylink radio, instead of the onstar box, so like DWALEX says, you shouldn't need a new onstar box.
Toasty is offline   Reply With Quote
Old 01-23-2014, 12:03 AM   #46
WarWolfX0
WarWolfX0's Avatar
I already have (on the way)
GPS/XM CBL KIT 13581173
ONSTAR/CELLULAR CBL KIT 13581174
Antenna 22739134
splitter 20960972
Some of the parts i still need are
Faceplate to radio harness?
Radio USB cable?
Console Harness?
which i will get from Gen5diy
I think i will have everything
but I think my old onstar already has bluetooth
the new onstar module 22903686 would remove it.
I am hoping i can get onstar to get the new module working maybe with the onstar app. 2010's don't have onstar app support, i think the 2011's have it working.
also this would be a cleaner setup instead of 2 Bluetooth's in the car.
will the new splitter/ant work with the old radio system.
I am just try to see if i can put the new ant in and test it before putting(getting) in the nav unit.
Old 01-23-2014, 12:36 AM   #47
Pagliaro
RIP Betsy ( Vitara )
Pagliaro's Avatar
Drives: '11 SGM 1LT/RS
Send a message via AIM to Pagliaro Send a message via MSN to Pagliaro Send a message via Yahoo to Pagliaro
If that's the case I am returning my Onstar box.
First retrofitted 2014 mylink.
Pagliaro is offline   Reply With Quote
Old 01-23-2014, 08:55 AM   #48
Toasty
Toasty's Avatar
Antenna 22739134
splitter 20960972
Radio USB cable?
Console Harness?
When info on the onstar app came out, those seemingly in the know here have said that switching the onstar box would not enable the app on the 2010's
I think Gen5DIY used their 2010 onstar box with the splitter and new antenna. Since I haven't seen install pics, not sure how they plugged in everything.
Old 01-23-2014, 09:08 AM   #49
The Stig
knows 2 facts about ducks
The Stig's Avatar
Onstar is linked to your VIN, so swapping out for a newer Onstar box won't fix the problem.
Click to view my build thread
Old 01-23-2014, 09:17 AM   #50
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Antenna 22739134
splitter 20960972
Radio USB cable?
Console Harness?
Bluetooth is part of the my link head unit now.
Old 01-23-2014, 10:25 AM   #51
DWALEX
DWALEX's Avatar
Probably we don't need swap the antenna if the onstar box 2010 works with mylink and then we just have to connect the GPS coax to the splitter. I will try the next opportunity or somebody else can try. We can save a lot work and some bucks
Old 01-23-2014, 11:10 AM   #52
Toasty
Toasty's Avatar
I was thinking that the supply voltages on the coax would necessitate the splitter
Old 01-23-2014, 11:15 AM   #53
DWALEX
DWALEX's Avatar
the Onstar module supplies 5V through the coax cable to power the internal antenna amplifier throuh the signal splitter. the radio supplies 5 V through the center conductor of the coax cable to power the splitter
Old 01-23-2014, 11:23 AM   #54
Toasty
Toasty's Avatar
My additional thought is that the splitter Separates onstar and GPS to separate connectors. Not just splitting both to two feeds. So without the splitter, the onstar and gps antenna would go to the head unit and there would not be a connector for the OnStar box gps feed.... Unless i butchered the routing in my head, lol
Old 02-04-2014, 08:45 AM   #55
k818mn1
Drives: 2016 Camaro SS, Garnet Red
The "universal coax" cables that are used to connect to and from the spllitter - are these obtained from the two coax kits (13581173, 13581174)? And are both kits needed - there seems to be a lot of cables in each kit and only three are necessary, one input to the splitter and two output.
k818mn1 is offline   Reply With Quote
Old 02-04-2014, 09:07 AM   #56
DWALEX
DWALEX's Avatar
Yes, I used 3 coax from 7
