09-01-2010, 11:42 AM | #43 |
Drives: Camaro SS/RS Join Date: Sep 2009
2SS/RS too.... no permanent light when the car runs too. :(
Any ideas?
Camaro SS/RS, summit white, Afterburner Taill., GMPP exhaust, 22inch Forgiato Inferno, T-Rex Grille, KW V1, RK Carbon Diffusor...
09-01-2010, 11:47 AM | #44 | |
Drives: 2010 Camaro 2SS L99 SIM Join Date: Feb 2010
09-01-2010, 11:58 AM | #45 | |
Drives: 2010 2SS/RS and 1985 L98 Corvette Join Date: Sep 2008
I ran a test with a 9volt battery with alligator clips to the prongs and I was able to power the OEM bulb by applying voltage to 2 of the prongs, the 3rd to ground. So from the looks of it, the car right now is only using 2 prongs(Blue and Black wires) and the middle prong has no voltage. This middle prong appears to be the one that needs the constant voltage from when the driving lights are on which makes no sense of why GM would not have done this. So Im just trying to get verification that either I am not putting in my bulb in all the way in or if I'll be having to run another wire (the constant voltage) to the middle prong. Im just confused as to why the OP mentioned that he had 2 wires (Black and Blue) that he used for his load resistor and his are working just fine. EDIT: If the OPs are working just fine and he only has the 2 wires into the plug then I dont want to be running no wire into the middle prong if this is not needed.
Since June 19, 2009 Owns:
2010 Camaro 2SS/RS IBM w/ SIM Rally Stripes w/ SIM GRFX Still Owns: 1985 Corvette |
09-01-2010, 12:16 PM | #46 |
Here is a pic I just took right now. You see the 2 red splicing connectors. One goes into the Blue wire and the other into the black for the load resistor. The other wire is where my halo is wired. Last edited by erk5000; 02-21-2012 at 03:31 PM. |
09-01-2010, 12:18 PM | #47 | |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
09-01-2010, 12:26 PM | #48 |
Yes, I put the load resistor on the blue(+12V) and black(Negative) wires as indicated by the instructions. Then I took them off and just left the OEM bulb to see if they were even on. I've been looking at other Camaro pictures to see if they have the front turn signals on when the driving lights are on but noticed most dont and only a few do. This was supposed to be an easy install.
09-01-2010, 12:32 PM | #49 | |
Specially when im asking for help
09-01-2010, 01:00 PM | #50 |
09-01-2010, 01:05 PM | #51 |
ZEUSS
How did you get the (white) turn/runing lights to stay on, or is your car a non-RS model?
With the RS model these light only blink and stay off otherwise. Looks good by the way |
09-01-2010, 01:10 PM | #52 |
Yes, my car is a non-RS model, that's how they are able to stay on. So now I'm thinking, does this mod only work with non-Rs model?
09-01-2010, 01:12 PM | #53 | |
ZEUSS
That's why I asked in the previous post. I am wondering if he might have used a new plug for the switch back bulb and got power from the halo's to run the white LED's on the new buld to come on with the halo's. Kinda like how everyone is making there DRL's come on with the halo's. |
09-01-2010, 01:21 PM | #54 | |
09-01-2010, 01:27 PM | #55 | |
ZEUSS
09-01-2010, 01:53 PM | #56 |
I guess what is an easy mod to install isn't so easy for the RS models... Damn.
Similar Threads | ||||
Eagle Eye Headlights with HIDs | erk5000 | Cosmetics and Lighting Modification Discussions | 234 | 03-03-2013 11:29 PM |
new eagle eye halo headlights | tallmantony | Cosmetics and Lighting Modification Discussions | 51 | 01-29-2012 09:11 PM |
Photoshop Request: Tinted Headlights & Foglights | SamSS | Camaro Photoshops / Renderings Forum | 13 | 02-22-2010 12:35 AM |
Turn signals / parking lights | Becustom | Cosmetics and Lighting Modification Discussions | 4 | 09-09-2009 09:53 PM |
I can see! | The_Blur | Off-topic Discussions | 31 | 07-01-2009 02:19 AM |
