Old 08-25-2009, 06:15 PM   #1
Becustom
ProCharged 600 + RWHP
Becustom's Avatar
Drives: 2SS/RS White/Hugger Orange
Question Turn signals / parking lights
Has anyone come up with a way to use the turn signals for the parking lights ? Like we used to do on the old cars , We always called them our cool lights . I know that is what they are using the Halo's for now but I would like to use the turn signals and the halos at the same time. Any help would be great.
And what about having the fog lamps and the headlights on at the same time.
Where is the wiring whizz's on the board ???
Becustom is offline   Reply With Quote
Old 08-26-2009, 10:26 PM   #2
cannondalerider
LSWEE
cannondalerider's Avatar
Drives: CGM LS3 2SS/RS
I just got to thinking, what if you make them 'inverted turn signals'. As in, the bulbs are always on, but when you use the turn signal, they blink off... In my 6, I added some lights to the lower bumper in some reflectors. Wired in positive from the brake lights into one lead and the positive from the turn signals into the other one giving the car extra brake lights that do inverted turns if I'm on the brake or regular turns if I'm not braking. What if you replaced the - line from the turns with a + from a running light? I don't have my car yet, or I'd try this...
1100 - Preliminary Order Accepted (7-22-09)
2000 - Accepted by GM (9-10-09)
3000 - Accepted by Production Control (9-11-09)
3300 - Scheduled for Production (9-21-09)
3400 - Broadcast (Being Built) (9-24-09) (9-28-09)
3800 - Produced (10-1-09) 2G1FT1EW6A9151459
4200 - Shipped (10-1-09) (in Calumet City, IL as of 10/3/09 7:00am)
cannondalerider is offline   Reply With Quote
Old 09-09-2009, 10:43 PM   #3
Jeffro19
Jeffro19's Avatar
Drives: 2018 ZL1 6M, Silverado High Country
Quick question? My parking lights do not come on when the headlights are on? Is this normal or should they be on. Mine is a 2SS/RS
Previous Camaro's - 2002 Z28 6 spd manual, T tops, Sebring Silver - 2010 2SS 6 spd manual, Cyber Gray Metallic
Current Vehicles - 2018 ZL1 Red Hot 6 spd manual, Carbon Hood, Sunroof
2019 Silverado High Country, Daily Driver
Jeffro19 is offline   Reply With Quote
Old 09-09-2009, 10:48 PM   #4
TheLazyBrownDog
Drives: 98 S10, 97 4Runner
RS equals Halos as parking lights.
To OP, you may be able to order housings and bulb harness from a non RS car and then just wire the extra lead from the light to the halos. Not positive if the housings are interchangeable though
2SS/RS IBM M6 Sunroof : She's home. 03SEP09
It is better to have loved and lost...
Than live with a Psycho for the rest of your life.
TheLazyBrownDog is offline   Reply With Quote
Old 09-09-2009, 10:53 PM   #5
TheLazyBrownDog
That should work, only thing is they will be quite bright, turn signal / running light bulbs have 2 filaments, one dim for running the other bright for turns.
Angel Eye Mod (93-97 Camaros) CamaroSpike23 4th Generation Camaros 105 05-12-2014 04:17 PM
Transparent Bow-Ties, Reverse Lights, Tail Light Trim Rings & Front Turn Signals 14pilot Cosmetics and Lighting Modification Discussions 16 04-28-2011 08:45 AM
Quick question about HID and Halo LIghts ttazzijr700 5th Gen Camaro SS LS LT General Discussions 81 01-30-2011 09:43 PM
Parking lights ? Becustom Cosmetics and Lighting Modification Discussions 1 08-16-2009 12:12 PM
Cowl Induction hood and reverse lights on 5th gen rray200 5th Gen Camaro SS LS LT General Discussions 77 01-15-2008 01:30 PM
