07-27-2023, 05:56 PM | #57 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
ANyone know what the Part number is for the ZL1 Bleeder screws? Are they different front and rear? I was able to locate on a GM website but they were listed as rears. I would like to replace the fronts.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
07-29-2023, 04:07 PM | #58 |
Current progress.
07-29-2023, 04:17 PM | #59 |
What is the correct torque spec for caliper bolts, I have heard30 lb for Front and Rear and I have heard 44 front 30 rear plus the angle, I also saw someone posted over a 100. What's correct? Thanks.
07-31-2023, 08:02 PM | #60 |
I got them installed and Bedded them in, everything feels good, I did run the master dry while bleeding ( stupid mistake ) I am going to bleed them once again just to be safe and see if the drive moved any air. My pedal does feel good but figured it can't hurt and I'll bleed the ABS again. I do believe the brakes are a bit more touchy/ Grabby on the initial activation.
08-09-2023, 08:26 PM | #61 |
So far so good with the brakes, The pedal is perfect ( I was worried since I ran the master dry but I did bleed it very well and ran more fluid though it then I probably needed to ). One thing I think I notice is they feel kinda numb or lacking feel at first, They do seem to get better the harder I use them. I have not gotten on them to much as I am dealing with a Drive shaft issue at the moment. Once I get the shaft figured out I will really get to try them out.
08-10-2023, 07:10 AM | #62 |
Looking good! Those front calipers are huge!
Roy
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
