12-28-2022, 04:34 PM | #1 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
ZL1 Brake Rotors, what are some good options? Conversion Part # and other questions.
Hi, I am thinking about doing the ZL1 Brake upgrade, I am just starting to put together a list of things, what are some good options as far as Rotors go?
I want to keep a 2 Piece in the front but not finding a lot of 2 piece rear options, DBA says they don't offer it because of parking brake issues. I like the look of the Slotted/Drilled rotors but am not making that a requirement. What are your guys thoughts, Car will see track days here and there but that is not it's primary use. I am thinking I would use factory pads. Thanks Added on 12-30-22 Below I believe are the parts I would need Besides calipers and Rotors, I have the Goodrich ZL1 Braided lines already, Are the Banjo bolts the same between SS/ZL1? I can Modify the SS Dust shields in the front to work with ZL1 Fronts since this part is hard to find? 3. ZL1 brake pads: ACDelco 171-1040 4. ZL1 brake rotors. Or after market. LF: AC Delco 177-1145 RF: AC Delco 177-1146 5. Brake Pad Pin Kit. ACDelco Gold Brake Hardware Kits 88875102 Front (18K2108X) ZL1 ACDelco Gold Brake Hardware Kits 19264180 Rear ( ADO-18K1970X ) ZL1 Chevrolet Performance Replacement Brake Caliper To Knuckle Bolts 11570788 Front ZL1 11515781 Rear Caliper Bolts SS/ZL1
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. Last edited by Joe.G; 12-30-2022 at 11:21 AM. |
12-28-2022, 07:21 PM | #2 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
I went with the DBA rotors and pads from KNS and I really like them. I have not had the opportunity to do a track day with them though I can tell you that they work fine at triple digit speeds.
12-30-2022, 07:11 AM | #3 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
+1 for KNS. Ken talked me OUT of overspending when I was doing the rear brakes on my track C5 Z06. I'm using DBA rotors and Carbotech pads. Give KNS a call.
12-30-2022, 07:21 AM | #4 |
I'll look into them,I really wanted a 2 Piece front and rear, Baer is the one of the only ones I see with a 2 Piece rear but don't offer a ZL1 Front.
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
12-30-2022, 10:57 AM | #5 |
Is there any reason you want two piece on the rear?
12-30-2022, 11:17 AM | #6 |
Figured any weight I can save would be good that really it.
I updated the post at the top to ask a few questions about the conversion.
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. Last edited by Joe.G; 12-30-2022 at 11:49 AM. |
12-30-2022, 11:01 PM | #7 |
Drives: 2011 2SS/RS Join Date: Feb 2016
You can get 2 piece DBA rotors front and rear for the ZL1 Fronts and SS/ZL1 Rears.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
12-31-2022, 04:09 AM | #8 |
Leo I called them and they told me they never offered 2 piece rear because of E Brake. Do you have a link?
12-31-2022, 06:36 AM | #9 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Giro Disc has a 2 piece rear.
Orange Krush II
12-31-2022, 06:50 AM | #10 |
Olblue75 I saw that they Are not cheap that's for sure, I was speaking with Baer and they said they were thinking of making Fronts then Covid hit and everything stopped if they did I would get front and rears from them.
Are the Banjo bolts the same between the SS and the ZL1 Calipers? When I added the ZL1 Goodrich lines I forget which bolts I used. GM Parts break down is no help. I am guessing it would be obvious where the Heat shields need to be trimmed?
01-03-2023, 12:50 PM | #11 |
Dust Shields Ordered from a salvage place, Now only needing calipers and rotors. I may make a post about colors, CTSV There are quite a few options and not sure what will look best with Ashen Grey.
01-04-2023, 07:37 AM | #12 |
What Year ZO6 and CTSV Calipers work on our cars?
01-04-2023, 11:19 AM | #13 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
C7 ZO6/Grand Sport iron brakes
2009-14 2nd Generation CTS-V 2017 to present Gen6 Camaro SS 1LE, excluding the optional 22+ BCD copper free brake package Tons of info here on the ZL1 package upgrade: https://www.camaro5.com/forums/showthread.php?t=348133
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
01-04-2023, 11:22 AM | #14 |
I thought 6 Gen Camaro brakes wouldn't work?
