05-08-2020, 06:40 PM | #71 |
Drives: Camaro ls Join Date: May 2020
05-23-2020, 09:39 PM | #72 |
Drives: 2013 camaro 2ss 1le Join Date: May 2020
on the flip side, how can i make it so the halos turn on for the drls with (preferably instead of) the fog lights?
2013 Camaro 2SS 1LE w/ RS [Rally Yellow]
Stock + Speed Engineering 1 7/8 LTHs w/ TSP HFCs, Roto-Fab CAI, Innovate DLG1/LC2 Dual WBo2, Smoked Wicker Bill, Self Tuned w/ HPTuners |
05-23-2020, 09:55 PM | #73 |
It don’t come easy.
I wired my halos so they come on as soon as the key is turned. Ran a piggy back from the engine compartment fuse box, then wired directly out to the halos. You can remove the spring from the light switch, so the drl’s and lights only come on manually. Do a search and you’ll find some threads about it.
05-23-2020, 10:05 PM | #74 | |
Drives: '16 2SS Join Date: Apr 2011
https://www.camaro5.com/forums/showthread.php?t=266497 |
05-23-2020, 10:16 PM | #75 |
ah neat, dont know if its $90/$120 neat but cool to know it exists.
01-28-2023, 11:06 PM | #76 |
Drives: 2013 1LS Join Date: Feb 2013
I have 2013 Camaro LS (non-RS). Back in 2014, I purchased OEM RS headlights and used the Non-RS to RS headlight harness #2 from Gen5DIY to run them. For anyone who doesn't know, the 4 pin RS headlights aren't plug-and-play on a non-RS Camaro (which has a 3 pin headlight connector). Two months ago, I started having problems with my headlights (passenger side stuck on high beam, driver side not working). I shot the problem down to the aftermarket wiring harness going out on me. When I ordered a new harness, I discovered that I now had a problem with the passenger side headlight not working unless I unplugged the passenger headlight and then plugged it back in almost every time I started my car. It ended up being a problem with the headlight itself. Instead of paying around $450 for a new OEM RS headlight, I decided to buy a whole new set of aftermarket headlights and install LED bulbs in them. I wanted the new headlights' LED halo/accent lights to function as the DRLs which means that I needed to disable the headlight DRL function (apparently LED and HID bulbs can flicker when running at the lower voltage that DRL headlights operate). I did as much research as I could (much of it on this forum), and came across a post where someone said that you could install a relay to disable the headlights as DRL. I wish I could find that post again to give that person credit. It got my gears turning, and I figured out that if you run the coil side of a standard 12V relay in parallel with the parking light wires, then run the headlight low beam wire through the switch side of the relay, the headlights will not function unless the parking lights are on, thereby disabling the headlights as DRLs. I drew up a wiring diagram to illustrate this, and included the wiring that runs my aftermarket fog lights in parallel with my headlights and the 50W 6 ohm resistor for my switchback LED parking/turn signal bulbs. I'm happy to say that it works. I have my headlight accent lights wired to the ignition fuse so they are on whenever the ignition is on (operate as DRLs), and the headlights only come on when the parking lights are on. The only weird thing about my setup is that when I have the ignition on but the engine isn't running, the headlights don't come on automatically when it gets dark, they have to be turned on manually. This isn't really an issue for me because everything works correctly when the engine's running. I'm including the wiring diagram I drew up as well as pics of my wiring for each headlight showing where I mounted the 12V relay for each headlight. I hope this info can help out anyone else looking for info on how to disable their headlights as DRLs without giving up any other functionality (i.e. headlights coming on automatically when it gets dark).
my wiring diagram: driver's side wiring (relay mounted outboard of headlight): passenger side wiring (relay mounted outboard of headlight): |
Similar Threads | ||||
Angel Eye Mod (93-97 Camaros) | CamaroSpike23 | 4th Generation Camaros | 105 | 05-12-2014 03:17 PM |
Disabling Daytime Running Light (DRL) | buddylok | Canada | 7 | 10-07-2009 08:09 AM |
Changing daytime runnning lights in 1ss | EAkrish | Cosmetics and Lighting Modification Discussions | 7 | 08-22-2009 10:28 PM |
Day Running Lights | trudawg660 | 5th Gen Camaro SS LS LT General Discussions | 15 | 04-07-2009 12:34 PM |
LED tails, running lights | mondain | Cosmetics and Lighting Modification Discussions | 13 | 02-16-2009 02:39 PM |
