06-06-2017, 11:46 AM | #99 |
Drives: 2013 Camaro SS LS3 Join Date: Jun 2015
Wow! Did they open the ring gap at all?
Sent from my VS990 using Tapatalk
Romans 5:8 But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. -Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20. |
06-06-2017, 11:48 AM | #100 |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
06-06-2017, 11:56 AM | #101 |
Switching to a colder plug then will make another pull before building the restrictor plate.
Pretty sure I am going with a bigger injector but I didn't know the 2000's were the old style and a pain to tune so I may back down to the 1700's.
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile Last edited by BiggFoot; 06-07-2017 at 06:07 AM. |
06-06-2017, 12:00 PM | #102 | |
06-06-2017, 12:16 PM | #103 |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
what a beast. You have what they call "good problems to have"
06-06-2017, 12:17 PM | #104 |
Oh My Gosh! It just made 1010 RWHP on a full pull with colder plugs. All of the previous pulls were shut off at 6300 RPM.
On the plugs we switched from 7's to 8's.
06-06-2017, 12:26 PM | #105 |
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
06-06-2017, 12:31 PM | #106 |
hurry up and post a pic of the chart you bum!
06-06-2017, 12:31 PM | #107 |
Ok, so here is the plan going forward. We are staying with the 8 series plugs, building a restrictor plate to limit the boost, and adding ID-1700X injectors.
Pretty sure the final HP will be down a bit but LOL, I am fine with that. This F-1X is a Hoss my friends. Will post the dyno vid and sheet here in a little bit.
06-06-2017, 12:32 PM | #108 | |
06-06-2017, 12:37 PM | #109 |
Ok, here is the previous Dyno sheet back in December with the Maggie:
Here is the one from this morning, but it doesn't look like he was monitoring torque on this pull, but we aren't finished yet. Pretty sure the final number will be considerably less that this!
06-06-2017, 12:42 PM | #110 |
Is that boost on the bottom? If so... you getting belt slip?
06-06-2017, 12:43 PM | #111 | |
Here is the Dyno Vid:
06-06-2017, 01:42 PM | #112 |
RealQuick I hear you bro, but I am paying these guys for their expertise so I am "sticking with the partner I brought to the dance."
