03-14-2015, 10:31 PM | #1 |
Drives: Black aSS 2011 - L99 Join Date: Apr 2012
Couple Q's for the NOS guys.......
Just fishing for ideas.....
Where are you mounting your LNC 200's and to save me time on AFR meter install, what color wire is the signal wire on the stock O2 sensors. Thanks in advance.
Staying stock and loving it............
03-15-2015, 02:00 PM | #2 |
100 views and no replies, but yet there is so much opinion about who knows what about Nitrous and no one is monitoring AFR with the stock sensors? LOL.....Ill go to the ls1 tech forums or just figure it out myself like always.
03-15-2015, 02:26 PM | #3 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
I'm 99.99% sure the stock o2s are narrowband sensors. You need to add a wideband. Also for the lnc2000 you could mount it the same place I mounted my ez tcu. Driver side kick panel up high. Easy access but we'll hidden.
maybe someone else will chime in, as the stock o2s and aftermarket o2s both use 0-5 volts for reading. But I'd imagine that the calibration would be off( different sensors, different ranges)
03-16-2015, 07:49 AM | #4 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
The stock narrow bands will not do you much good, as they monitor around stoichy. You will need to add a bung at least on one side for the wide band sensor. As far as the LNC goes, I made a mount for it under the hood.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
03-18-2015, 04:27 PM | #5 |
Hey Badbubba....
Thanks guys. Yes I know the stock sensors are narrow band stoich. I have narrow band gauges, (one for each side), from Dynotune Nitrous. So I was looking for the signal wire, but I already found it. These gauges are much cheaper than a wide band setup and just read differently. Pics of the mount under the hood Badbubba?????
03-19-2015, 03:24 PM | #6 |
GrINned & JUICEd
S5 phone won't upload new pics. Best I can do is link to an old thread. http://www.camaro5.com/forums/showthread.php?t=217103
