03-15-2017, 02:11 PM | #1 |
Drives: '17 ZL1 Join Date: Jul 2016
ZL1 M6 Normal Transmission Temp
I just took delivery of my ZL1 (6-speed manual). On the way home, about 70 miles of interstate, I noticed the transmission temperature gauge didn't move from 100 (the minimum temp).
It was only about 29 degrees outside, but I would have still expected the transmission temps to exceed 100 degrees. I hoping it's normal, but I'm guessing it's not. The next best scenario would be a faulty sensor. In the back of my mind though, I'm wondering if somebody forgot to add the fluid to the transmission. What do you guys think? |
03-15-2017, 02:56 PM | #2 |
I used to be Dragoneye...
The ZL1 has a very aggressive transmission cooler that is a separate circuit from the radiator. It includes a duct underneath that increases airflow through this heat exchanger even more than the SS's design.
So if you were traveling at highway speeds for an extended period of time at 29º ambient, with no stops, accelerations or aggressive cornering that might cause the eLSD to generate heat...it wouldn't surprise me to not see over 100º temps. What was your coolant and oil temps doing? I suspect rarely going beyond 190? |
03-15-2017, 04:11 PM | #3 | |
Drives: 2018 Camaro ZL1 1LE Hyper Blue Join Date: Dec 2015
Welcome to the ZL1 family. Howard
2018 ZL1 1LE Hyper Blue Metallic
2005 Silverado 2500HD Crew Cab 1987 Camaro IROC-Z White T-Tops Instagram @Gen6ZL1 Last edited by hadkins2; 03-15-2017 at 04:12 PM. Reason: Added Sentence. |
03-15-2017, 04:13 PM | #4 |
Post some pics!!!
Howard
2005 Silverado 2500HD Crew Cab 1987 Camaro IROC-Z White T-Tops Instagram @Gen6ZL1 |
03-15-2017, 05:23 PM | #5 |
KaBoom1701
And your complaining about that.......lol
Mods:
03-15-2017, 05:34 PM | #6 |
03-15-2017, 05:35 PM | #7 |
03-15-2017, 05:37 PM | #8 |
03-15-2017, 08:59 PM | #9 |
03-15-2017, 09:19 PM | #10 | |
Drives: Slow Join Date: Mar 2016
2016 Toyota 4Runner
2017 Camaro ZL1 |
03-15-2017, 09:29 PM | #11 | |
KaBoom1701
Mods:
03-16-2017, 08:46 AM | #12 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
When I bought and drove mine home on Saturday the temp here was in the mid 50's and I checked my trans temp and it was just slightly above the minimum 100 readout, like maybe 110-ish. The trans coolers are really good on these 6th gens.
