09-12-2020, 04:43 AM | #3613 |
Drives: 2012 ZL1 #1329 M6 Join Date: Jun 2009
2012 Camaro ZL1 #1329 M6 Summit White
Built by Mike @ Rapid Motorsports 784rwhp 757 rwtq on 93 Octane ET - 10.97 @ 128 Heads-Blower-Snout-TB ported & prepared by Jeremy Formato of FasterProms http://www.camaro5.com/forums/showthread.php?t=395950 Rapid Motorsports 396ci Build https://www.camaro5.com/forums/showt...1#post10321301 10.832 @ 130.99 Last edited by Dutchman427; 09-12-2020 at 05:13 PM. |
09-15-2020, 02:33 PM | #3614 |
Drives: Nickey Super Camaro Join Date: Nov 2008
Category 11
Union Grove Wisconsin / NicKey ZL1 2015 LSA-A6 Rear tires 305 35R 17 Mickey Thompson Street R.........17 psi Front tires 28x6.00-17 M&H Front Runner...........40psi 5" inch CAI Interchiller NicKey ported snout ARH 2" LT headers 2.55 upper pulley 9.55 lower pulley NicKey Stage II cam/Kit Squash, Intank e85 controller Circle D Converter Stock Suspension Category submitted for: 11 R/T........... .322 60'............. 1.563 330'........... 4.290 660'........... 6.547 660’ mph... 109.91 1000'.......... 8.486 1320'.......... 10.151 1320’ mph… 136.40 Name of the track: Great Lakes Drag Way Date of pass: 05/16/20 Weather conditions: 80 degrees 60% humidity 2800 DA Last edited by NicKey; 09-15-2020 at 04:16 PM. |
09-24-2020, 09:42 PM | #3615 |
Drives: 13' 1LE Join Date: Apr 2012
11.5@124mph N/A, +270 DA. Wheel hop and 1.9 0-60ft, on Nitto NT05R.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
09-26-2020, 09:11 PM | #3616 |
Drives: 2013 Camaro SS M6 Join Date: Mar 2019
2013 LS3 LTH, CAI, PTB, PIM&rod-mod, UDP, 91oct tune, 3.91 gear, On Street Tires
12.36@115.60 12.57@115.93 Weather conditions on the slips, not many ****s given about reaction time as you can see haha ! |
09-28-2020, 06:19 PM | #3617 |
Drives: Black 2010 2ss Join Date: Jun 2015
Category 5 update please!!!
2010 Camaro SS Tires used on the pass: M/T radials. Performance Mods (if any):heads, cam, Tb, LT, gears, converter and th400, DR, skinnies,tune and WR Category submitted for: #5 Internal Engine Mod Plus Bolt Ons R/T.......... 0.477 60'............. 1.309 330'........... 3.856 660'........... 5.976 660’ mph... 115.62 1000'.......... 7.824 1320'.......... 9.402 1320’ mph… 142.44 Name of the track: No Problem Raceway Date of pass: 25September2020 Weather conditions: Unknown DA
the parts never end!!!!!
09-28-2020, 06:23 PM | #3618 | |
CamaroFans.com
09-28-2020, 09:15 PM | #3619 | |
Drives: 2012 ZL1 Join Date: Mar 2020
'12 ZL1 - RPM 5", TSP 2" headers, Speed Engineering 3" header back, Dayco 8.66 lower/LPE 2.38 upper with solid isolator and 10 bolt hub, hand ported blower and snout and went way too far, ID1050x's, DSX aux harness with a summit 400lph pump on E, NGK TR8's with Taylor wires, 160* tstat, NW 102, UPR catch cans, HP Tuners, Stock unopened long block
10-18-2020, 12:20 PM | #3620 |
Drives: 10 SS A6 Huron TT Join Date: Oct 2016
Category 6, I believe I am the new #9 spot:
9.7951 @ 140.76 Car is SBE, unported heads and intake, stock exhaust manifolds, stock driveshaft, stock untouched 3.27 diff, stock halfshafts. 6L80 Mods are Hurron Speed twin turbo (6065 oil-less turbos). Pump e85 flex fuel system, Texas Speed stage 1 blower cam, 17in drag radials, Vigilante 3200 converter. Tuned by PowerDynamics Car is a 2SS Sunroof car with full interior and AC. Tailpipes out the back. |
10-20-2020, 01:02 PM | #3621 |
I agree, more details are needed! I am TT and E85 and not that fast |
10-21-2020, 11:04 AM | #3622 |
Sucker Punch
Drives: 2013 Black ZL1, 2007 Silverado LTZ Join Date: Jul 2014
Ya I'm in for some details on this?
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
10-26-2020, 12:42 PM | #3623 |
Drives: 2015 1SS LSA blower,heads cam Join Date: Jul 2017
Time slip submission
Hello guys.
2015 1SS M6 SBE Ported LSA blower PTB. 9-10 Psi 665whp on dyno jet Tuned by DSM lights in Miami fl. Cam,Heads,LT, 3inch FE CAI,E85,3.90’s GMPP gears, GForce DS Mcleod RXt 1200 clutch. Stock trans Stock diff, stock axles Weight Reduction. 3850+ Race weight. 17’s drag pack MT ET street R tires. 2000+ DA Bradenton Motorsports Park FL |
11-05-2020, 09:14 AM | #3624 |
Do we need someone new to update the list?
I know the Camaro6 6th gen page list also needs updating too. I think same person was running this and that one, but disappeared
2010 2SS RS / A6 and Sunroof / Huron Speed TT / cam/ E85 fuel system / 3200 stall / SBE
11-06-2020, 11:45 AM | #3625 |
Drives: 2010 SS L99 Join Date: Sep 2018
The updates stopped last year from what it looked like. Haven't seen Merc in a minute
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
11-11-2020, 02:47 AM | #3626 |
Drives: 14 Camaro SS LS3/M6 Join Date: Jul 2016
LS3/M6 - Cam, Heads, LT, CAI, PTB & Intake, 3.91 Gears, Tuned, 18'' Wheels, Slicks 11.374 @ 124.08MPH
2014 LS3/M6, SS4NFC, GPI Heads, Ported Rod/Mod Intake, LTH, PTB, UDP, CAI, 3.91, LSA Injectors and Fuel Pump, E85, Tuned by GPI 532rwhp/473ft-lbs tq. 11.37 1/4 Mile @ 124 MPH, Member of the SBE Killaz, Founder of the River Valley Camaro Club. IG @ARCamaro5
Similar Threads | ||||
Transcript of Camaro ZL1 Q&A Webchat with Chevrolet | Tran | Camaro ZL1 Forum - ZL1 Specific Topics | 42 | 12-22-2017 04:42 AM |
Modern Camaro Performance Parts - www.PartsTaxi.com | PartsTaxi.com | Sponsor Announcements / Giveaways / Contests | 0 | 10-06-2010 04:26 PM |
Official 1/4 Mile 2010 Camaro Stock Pirelli's Fast List | GQ4Life | Dragstrip and Launch Techniques Discussion | 17 | 07-07-2010 12:31 PM |
Official Camaro Convertible CONCEPT Press Release | Tran | Camaro Convertible Forum | 12 | 11-18-2009 07:05 PM |
