Old 06-09-2014, 02:42 PM   #1
timshifty
timshifty's Avatar
Drives: 2012 2SS/RS
(2) 12 Inch JL Audio W6 ---- HD 1200/1
Will this be good enough
JL Audio HD 1200/1 running (2) JL Audio 12 INCH W6's?
Flowmaster American Thunder Exhaust
timshifty is offline   Reply With Quote
Old 06-09-2014, 02:52 PM   #2
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
good enough for what?
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 06-09-2014, 02:57 PM   #3
timshifty
timshifty's Avatar
Drives: 2012 2SS/RS
to run those subs..lol
Old 06-09-2014, 05:31 PM   #4
flyer08
Drives: 2010 2SS/RS
That should be fine, are you no longer using the sub output on the 900/5?
flyer08 is offline   Reply With Quote
Old 06-09-2014, 05:43 PM   #5
timshifty
timshifty's Avatar
Drives: 2012 2SS/RS
right now i am but i am going to buy the 1200/1 and add another 12 w6
not enough bass
Old 06-09-2014, 08:14 PM   #6
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
Well, if you run much more than a 1200/1 to them you'll have a hard time getting them to warranty the 12w6's if you beat on them.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 06-10-2014, 11:41 AM   #7
timshifty
timshifty's Avatar
Drives: 2012 2SS/RS
Now my next question
Are running both amps going to require upgrading the alternator or anything else?
JL Audio says I would need to ?
(From JL Audio) Hello Tim, you could actually add another 12W6v3 on the amplifier you have now. You will gain output just by adding another subwoofer. Your vehicle will definitely require upgrades if you choose to add HD1200/1. The Big 3 and alternator will need to be upgraded. I would try adding the second subwoofer and this alone will give you more bass even on 500 watts. You could also try using a ported enclosure which would then give you even more output on the same power.
Sincerely,
Eric Cole
JL Audio Technical Support
Old 06-10-2014, 12:09 PM   #8
lfree11012
lfree11012's Avatar
Drives: 2018 1LE
Sincerely,
Eric Cole
2 12w6. Will be more then enough bass on the HD 1200. And if your port them you should be to bounce a quarter off the deck lid I had 2 13 w6 when the made 13 in a sealed box in my gli and a jl 1000/1 I had a 15 min rid to work by the time I got there my left ear was numb and tears would not stop running out of my right eye and I was just running 4 2 Fred cap
lfree11012 is offline   Reply With Quote
Old 06-10-2014, 12:14 PM   #9
timshifty
timshifty's Avatar
Drives: 2012 2SS/RS
what about the power and it sucking to much from the battery?
Old 06-10-2014, 12:26 PM   #10
lfree11012
lfree11012's Avatar
Drives: 2018 1LE
If any thing upgrade the batter first to one whit a higher amperage output like a red top or two batter wired in parallel they will Need to be the same batters or and another batter with an isolator should be fine I would not replace alternator
Old 06-11-2014, 01:37 PM   #11
darkrider01
+1. I have a stock alternator in my car, but I did upgrade the battery. Class D amps are a lot more efficient as well, so I'd say you'll probably be fine with the stock alt. The stock battery in the Camaro is pretty big, so you'll probably be fine with it also. I would personally just use the stock battery until I saw dimming headlights after the HD1200/1 goes in.
