![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Blk/Blk 2018 Sierra SLT Join Date: Dec 2006
Swapping ECM for tuning
What do you guys think about buying a seperate ECM and using that for a custom tune, and keeping the original, well original, in case the warranty is ever needed
I really want some long tubes and the tune only vararam but I really dont want to void my warranty Thoughts?
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6 |
Scout Sniping
just have your tuner save the stock tune. This way if there ever is an issue he can just flash it back to stock.....
Eric
Previous Car:1SS/CGM 6MT w/ Sunroof & FACTORY BLUETOOTH!!!: New Era OTR, Steeda Short Shifter, Ported TB, Stg 2 ported intake manifold, Fasterproms, Poor man down pipes, MBRP 3" Exhaust!!! Now I drive a F150 Supercrew |
But cant the tech's see that the ECM has been reflashed?
Drives: 2001 T/A, 2010 2SS/RS, 2006 Z06 Join Date: Apr 2009
Thanks dragon, so you think my plan will work? I mean, is there anything that would be obvious if I one day reinstalled the OG ECM? Would they be able to tell it was disconnected and reconnected?
#6 | |
![]() ![]() EDIT: Try to only use the flashed PCM when you plan on running the car hard. If you are heavily modded, you will need to keep the flashed PCM at all times to run properly. |
#7 |
![]() Drives: 99 camaro Join Date: Sep 2009
how big of deal is it to change them and where do u get one
Soon to own: 1SS CGM M6
#8 |
Dog Is My Copilot
Drives: 2011 2SS/RS LS3 Join Date: Jun 2009
This is exactly what I did with my GMC...I bought a second set of modules (PCM/TCM) and had them tuned. The stock modules are in a box in the garage should I require warranty service. However, I truly believe that if the Techs dig deep enough, they will be able to tell that the modules have been swapped. Something I've read about timelines in the programming.
#9 | |
#10 |
Dog Is My Copilot
The TCM is for the auto transmission in the trucks...M6 shouldn't have one. I'm not sure about the L99s, though...
#11 |
If you need an ECM, I have a spare I was planning on using, but then decided I will get a cam soon, so warranty will be gone anyways. Let me know if interested. It's for a SS M6.
#12 |
Scout Sniping
Some ecus are flashed multiple times from the factory, even 5-6 or even ten times. Just an FYI. This ensures optimum qc.
Eric
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: The Imperial Army Join Date: Feb 2009
#14 |
Scout Sniping
Very good point, forgot about that thread!!!!!!!!
Eric
INTENSE Camaro ECM Tune w/ HP Tuners Package | Rob@Intense | V8 Bolt-Ons & Tunes | 2 | 09-14-2009 01:48 PM |
my tune with updated segment swap | camaro1 | Tuning / Diagnostics -- engine and transmission | 2 | 08-24-2009 02:34 PM |
The Much Awaited #230 (L99) Update. | Scott@Bjorn3D | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 140 | 08-20-2009 09:52 AM |
ECM Replacement? | UCF w00t | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 23 | 06-15-2009 07:33 PM |
ECM Tune Questions | RyanG | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 11 | 06-09-2009 10:12 AM |
