Old 12-02-2012, 08:38 PM   #1
FRANK121
FRANK121's Avatar
Drives: 2022 Camaro ZL1
Might Have Screwed Up
I ordered My early Christmas presents Saturday and I hope I didn't screw up
I ordered 2 Boston Acoustic G2-12 Dual Voice Coil 12" Subs because I have had great success with them in another car. I ordered the box from ******** and I figured I might as well upgrade My existing sub amp since it is about 5 years old, came out of previous car. I ordered the Rockford Fosgate Punch P700-1bd figuring it is better to have more power than you need
The woofers are rated at 300 watts RMS and a peak of 600 watts and are 2 ohms. This is where I may have screwed up? I was thinking 2 ohm speakers = 2 ohm load which would be putting 450 watts RMS to the woofers. That would be right in range.
Now I just found out that with 2 woofers I will be a 1 ohm load and that jumps up the amp to 700 watts RMS and a maximum of 2500 watts
Can I turn down the gains on the new amp or did I just screw up
The subs are going in a sealed box because I like the tight chest pounding bass and listen to mainly mid 80's rock to present.
Suggestions? Everything has already shipped
Also, I see everybody using Dynamat through out the car in the trunk? Can I just Dynamat the inside of the sub box and secure it in the trunk?
2022 Black ZL1
RotoFab CAI, AWE Touring Edition Cat Back Exhaust.
665 Crank hp. est. and 660 Crank ft. lbs. est.
Never been Dynoed
FRANK121 is offline   Reply With Quote
Old 12-02-2012, 09:25 PM   #2
Superfly1
Superfly1's Avatar
Drives: 2010 Camaro 2LT #2197
If they are dual 2 ohm voice coils, then you can run the coils in series, making them 4 ohm. Then you run them in parrallel to the amp creating a 2 ohm load... You may have to still mess with the gains. 2ohm is more stable on amps than 1ohm. Your equipment will last longer.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
CAI intake | OBX LT Headers | Flowmaster AT Exhaust | Trifecta Tune | SS Rear Diff, Axles & Driveshaft
Zex 100 Shot Nitrous | Konig Airstrike Wheels | Custom Engine Cover, Fuse Box & Underhood Bowtie
Eibach Springs & SS Sway Bars
| BMR Strut Brace | Drake Shifter | Vitesse Paddles | 13.26 @ 105.88 mph
Superfly1 is offline   Reply With Quote
Old 12-02-2012, 09:37 PM   #3
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
What is OHMs law? Parallel would be different than 2 ohms right?
Skylane765 is offline   Reply With Quote
Old 12-02-2012, 10:00 PM   #4
FRANK121
FRANK121's Avatar
Nope, They are dual 4 ohm voice coils operating at 2 ohms and I cannot find anyway to wire two of them to where they end up a 2 ohm load?
The new Rockford Fosgate amp says:
"The P700-1bd mono subwoofer amp dispenses 225 RMS watts at 4 ohms, or you can wire your subs for lower impedance to achieve higher power output — all the way up to 700 watts at 1 ohm."
2022 Black ZL1
Never been Dynoed
Old 12-02-2012, 11:11 PM   #5
FRANK121
FRANK121's Avatar
Well the manual says: "The amplifier is 1-ohm stable (700 watts x 1) and will drive a pair of 4-ohm DVC subwoofers or quad-configuration of 2-ohm DVC subwoofers with ease."
My only concerns now are My 2 Woofer Wattage Specs:
Specifications:
Power Handling:
Peak: 600 watts
RMS: 300 watts
Impedance: Dual 4 ohms
RadialVent rigid cast aluminum chassis
RadialVent cooling directs airflow around the voice coils for increased power handling
Dual 4 Ohm Voice Coils
2-1/2" 4-Layer Voice Coils
SureSet impedance selection provides simple impedance selection as well as overdrive protection
2" peak to peak excursion for devastatingly accurate, deep bass output from small sealed enclosures
Rugged input terminals accept bare 8 gauge wire or pin connectors
Integral sealing gaskets ensure tight seals for any mounting configuration
Also I'm curious if anyone has ever put Dynamat inside a speaker box?
2022 Black ZL1
Never been Dynoed
Old 12-03-2012, 02:56 PM   #6
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
Specifications:
Power Handling:
Peak: 600 watts
RMS: 300 watts
Soo.....you're worried about sending 350 watts to each sub? The output will be divided equally between the 2 subs. Those subs should be able to handle that power with ease.
In short, you should be just fine.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 12-03-2012, 04:24 PM   #7
FRANK121
FRANK121's Avatar
Ok, Thanks
I guess I should have ordered the 1000watt then .... lol
2022 Black ZL1
Never been Dynoed
Old 12-03-2012, 04:29 PM   #8
Decibel JJ
Car nut
Decibel JJ's Avatar
Drives: Tahoe Z71, Race cars
If they are dual 4ohm, than you can wire it to mono 4ohm or 1ohm.
You'll be ok just turning down the gain some, just be aware of overdriving them or distortion/clipping as that will burn the voicecoils faster than anything else.
Quote: Don't you just hate it when Satan steals your ride and does all these weird ass mods to it?
R.I.P. Evan .. A true Friend
Decibel JJ is offline   Reply With Quote
