Old 07-10-2016, 11:25 PM   #1
Stockish_SS
Drives: 2015 camaro 1SS
Stick cars. I need input
Alright you gear grabbing guys. I finally got a good tire on my car and just ran a 12.3 @ 115. That being said. I really think if I get my launch down perfectly it could clip a 11.9-12.0. I cut a 1.8 60' but I slipped the clutch quite a bit, if I can knock that down to a 1.6 I would be pretty happy.
Car is a decent size cam and full exhaust only car. Makes in the ball park of 460-470 to the wheels. And next year I plan on spraying a 150 on it.
My question is what clutch do you suggest. I've been looking at the McLeod RXT. But there is a ceramic and a metallic version. Which would withstand slipping better. Or do you have any other suggestions other than a McLeod? Only thing that worries me is I hear that they don't like being slipped at all. And I need a little slip otherwise it wheel hops pretty bad. I already have BMR toe rods and trailing arms. But not control arms.
Input is greatly appreciated
Stockish_SS is offline   Reply With Quote
Old 07-11-2016, 09:04 PM   #2
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
I run the RXT. I was told the RST didnt like to slip. So far it hasnt hiccuped once. It has a slight shudder during normal driving, but you learn to drive around it.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 07-12-2016, 07:01 AM   #3
CGbambam
Drives: 2011 Camaro 2SS
RXT all the way, I daily beat mine with 900 rwhp
CGbambam is offline   Reply With Quote
Old 07-12-2016, 12:58 PM   #4
Stockish_SS
Thanks for the input guys. Do you use the ceramic or metallic friction material one?
Old 07-12-2016, 02:26 PM   #5
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Ran 10's with a rxt
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 07-19-2016, 04:16 AM   #6
Dutchman427
Dutchman427's Avatar
Drives: 2012 ZL1 #1329 M6
I would also consider a Monster Clutch man! Steve is a great guy to deal with!
2012 Camaro ZL1 #1329 M6 Summit White
Built by Mike @ Rapid Motorsports
784rwhp 757 rwtq on 93 Octane ET - 10.97 @ 128
Heads-Blower-Snout-TB ported & prepared by Jeremy Formato of FasterProms
http://www.camaro5.com/forums/showthread.php?t=395950
Rapid Motorsports 396ci Build
https://www.camaro5.com/forums/showt...1#post10321301
10.832 @ 130.99
Dutchman427 is offline   Reply With Quote
Old 07-26-2016, 02:19 PM   #7
Centerforce_Clutches
Centerforce_Clutches's Avatar
Drives: Chevy Camaro
Our DYAD dual-disk is another option you could consider. It has a easy stock-like engagement, but is rated for upwards of 1300 ft/lbs. Its the perfect clutch for driving around town one day, then doing a full blown track event the next!
Centerforce_Clutches is offline   Reply With Quote
