Old 08-31-2013, 02:14 PM   #1
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
Pulley and belt...vortech
I'm running the JRE 3.33 and belt upgrade...looks like I should have plenty of tension to drop to a 3.12...right?
When doing the math on the blower rpm..you have to take in account the 3.6:1 ratio of the v3 si also..right?
2questions...I'm done. Lol
-John S.
Old 08-31-2013, 02:47 PM   #2
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
From JRE 3.33 and belt upgrade I just added a 3.12 with that same belt. 12-14 psi and no slip. I'm on the YSi but pulley and belt is the same
DarkCry956 is offline   Reply With Quote
Old 09-01-2013, 05:07 PM   #3
grocerygetter
instigator
Thanks man. I'm looking to buy with cam to keep boost at 10.x psi or so. I need to talk to ryan and see what he thinks about adding boost now. Lol I'd bet it would be methanol territory though.
-John S.
Old 09-01-2013, 05:27 PM   #4
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
The 3.33 is the lowest you should go without meth on 93 octane. With cam it should put you at 650rwhp.
K32 Camaro is offline   Reply With Quote
Old 09-01-2013, 05:48 PM   #5
grocerygetter
instigator
Pulley size matters not for octane. Boost does. In other words...all depends on what the cam does or doesn't bleed off.
-John S.
Old 09-01-2013, 08:51 PM   #6
DarkCry956
DarkCry956's Avatar
I was recommended 3.33 with 93 oct and a 3.12 for a race fuel only tune or meth.
Old 09-01-2013, 08:57 PM   #7
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
This couldn't be more wrong, boost doesn't have anything to do with octane required. Dynamic compression ratio determines the octane you have to run and not run into detonation. Dynamic compression is directly rated to horsepower, and you'll have to stop at 650 wheel to be safe on your stock motor.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 09-01-2013, 09:08 PM   #8
DarkCry956
DarkCry956's Avatar
Do you mean 650 RWHP for the stock block on just 93 oct?
Old 09-01-2013, 09:15 PM   #9
Supercharged SS
Drives: 2010 Camaro
Yes. To be safe. Obviously you can go higher but the chances for kaboom greatly increase.
He can only make 650 wheel with his car that's why he's so angry. Please bear with us as we adjust his medication.
Old 09-01-2013, 09:18 PM   #10
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Oh great....here we go again with your 2 cents. Mr. Wonderful, with a broke car.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 09-01-2013, 09:19 PM   #11
DarkCry956
DarkCry956's Avatar
What about with meth like grocery said? Or racefuel like I was suggested?
Old 09-01-2013, 09:24 PM   #12
Supercharged SS
Drives: 2010 Camaro
Race fuel YES!
The consensus on using meth as a fuel is that it's not the greatest idea. The slightest hiccup and boom.
At least with race gas you know exactly what you're getting.
Lots of cars making 800 rwhp on the stock block with race gas or meth. I'd prefer the gas but both work.
Old 09-01-2013, 09:57 PM   #13
K32 Camaro
V8 lounge member #5
Race fuel YES!
+1 but my wallet says meth! (And so does my beer! lol.)
Old 09-01-2013, 10:01 PM   #14
Supercharged SS
Drives: 2010 Camaro
What's wrong with using $13 a gallon fuel?
