#Camaro6
AWE Tuning
Old 02-12-2017, 10:12 AM   #1
Sub
Sub's Avatar
Drives: 2017 ZL1
Snow drivers.. weighting rear?
Has anyone put sand bags or something in? Has it improved traction?
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
Sub is offline   Reply With Quote
Old 02-12-2017, 01:17 PM   #2
tecmec
Drives: 2016 2SS
Proper winter tires are a better idea.
tecmec is offline   Reply With Quote
Old 02-12-2017, 01:31 PM   #3
TopHatPlus
Drives: 16 2SS NPP MRC
I did!
I bought 2 tupperware containers, and put 180 lbs worth of safety stone in them. Didn't want to make a mess of the trunk.
(i also have winter tires on my car)
Skip to 5:12 to see what i did
TopHatPlus is offline   Reply With Quote
Old 02-12-2017, 01:36 PM   #4
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Love me a good set of winter tires.
Weight is not necessary because we're not dealing with pickup trucks, or solid-rear axle cars...that and the weight balance is good in these things.
Just keep T/C on...car works brilliantly.
Old 02-12-2017, 01:37 PM   #5
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
2017 1LT RS I4 A8 BLACK ON BLACK
Kindness and compassion #OthersFirst
Michigan1LTRS is offline   Reply With Quote
Old 02-12-2017, 02:18 PM   #6
hotlap
hotlap's Avatar
Drives: 20 1LE 2SS M6 Rally Green
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.”
Ronald Reagan -
hotlap is offline   Reply With Quote
Old 02-12-2017, 03:17 PM   #7
enzia35
Drives: '16 Garnet Red 1SS
Is that chunking on the stock summer tires???
'16 Camaro 1SS
'18 Miata GT
Gone: '01 Camaro, '14 Camaro, '90 Miata
enzia35 is offline   Reply With Quote
Old 02-12-2017, 05:50 PM   #8
Zodiac
Sarcasm Personified
Drives: 2017 Charger R/T Scat Pack
You're definitely gonna want a dedicated snow tire. I used to drive my 05 Mustang in the winters when I lived in New York. I did it on all season with probably about 150lbs of cat litter in the trunk. It was cheap and if you got stuck you could always pour it down around the rear wheels for extra traction.
Zodiac is offline   Reply With Quote
Old 02-12-2017, 06:07 PM   #9
Sub
Sub's Avatar
Drives: 2017 ZL1
I have good snow tires, but we got like a foot here and its not working. :O I'm trying to see if it helps..
Old 02-12-2017, 06:16 PM   #10
TopHatPlus
I flopped back and forth for a while, the issue is traction, and the weight can't hurt, i spent $50 on the weight and containers so i can just lift them out in the summer and there is no mess what so every.
Old 02-12-2017, 06:35 PM   #11
fastball
Banned
Drives: 2017 Camaro 2SS 6MT
When accelerating from a dead stop, start in second gear. Then keep the engine as low as possible in the RPM range on each gear (If you have the automatic keep it in manual mode at all times).
fastball is offline   Reply With Quote
Old 02-13-2017, 09:00 AM   #12
nfboy
Drives: 2017 Camaro 1LT HBM
Using Snow/ice mode is a better idea.
nfboy is offline   Reply With Quote
Old 02-13-2017, 09:23 AM   #13
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Even these cars are nose-heavy by a few percent, so a LITTLE extra weight in the trunk will help get you moving.
But too much carries the risk of having the tail being harder to catch if it does start coming around on you. Whether it's harder on you directly or harder for Stabilitrak to cope with is irrelevant.
I wouldn't add more than about 100 lbs. The car in my sig has never had even that much added over its OE trunk load.
Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously)
Norm Peterson is offline   Reply With Quote
Old 02-13-2017, 10:17 AM   #14
NUCAR
Drives: 68 big block
Couple of ammo cans behind the front seats.
NUCAR is offline   Reply With Quote
