09-21-2014, 10:38 PM | #1 |
aerosportconcepts@gmail
Drives: '15 1SS-RS/1LE (RRM) Join Date: Dec 2011
'14-'15 1LE with ZL1 Rear Diffuser
Anyone out there change the Rear Diffuser to a ZL1 Diffuser. I know the sides extend down a little more than a Stock SS w/ NPP. Looking for pics and how the trim around the exhaust fits. Looks like a pretty simple change. Any input would be great.
09-23-2014, 10:57 AM | #2 |
Drives: '14 1le Join Date: Jan 2014
I was going to get the z/28 rear diffuser bc it looks better and it's painted, but I don't think you can buy it w/o buying the rest of the aero pkg. it's on the spring edition camaro also.
10-01-2014, 07:54 AM | #3 |
Drives: 2014 Summit White 1LE Join Date: Sep 2013
Yep, fit perfectly. No modifications necessary. Didn't buy exhaust heat shields either and all is well. I'll try to post some pics later.
10-01-2014, 10:23 PM | #4 |
Here's a pic on my 1LE.
10-01-2014, 11:35 PM | #5 |
I've just got done painting mine. Thanks for the input. Post pics once I get it on her.
04-13-2015, 03:43 PM | #6 |
Drives: 1LE Join Date: Feb 2013
Reviving this thread. Hoping to get some clarification.
There are numerous threads on the ZL1 diffusers, but most are for the 2010-13 model years, and few talk about upgrading from 1LE. For the 2014/15 1LEs, what do I need to go to the 2014 ZL1 diffuser? I'm seeing the diffuser and (optionally) heat shields. No absorbers or other miscellaneous pieces? |
04-13-2015, 03:49 PM | #7 |
HTCC Member
Drives: 2018 ZL1 1LE HBM Join Date: Oct 2014
All you will need is the dIffuser it is a direct replacement. Same thing with the Z28 or spring edition diffuser
04-13-2015, 03:52 PM | #8 |
Really? That's good news -- looked like a $hit load of parts were needed for the 2010-2013 models . . . and lots of drilling/cutting.
04-13-2015, 03:57 PM | #9 |
HTCC Member
I install the Z28 diffuser on mine no cutting at all there are about 10 bolts and a bunch of clips that hold it on. Here is the DIY that i follow to get it off.
http://www.camaro5.com/forums/showthread.php?t=341496
04-13-2015, 04:05 PM | #10 |
I saw that thread, thanks, and I'm confident I can get it installed . . . if I have the necessary parts. I'm more concerned at this point in getting a handle on what exactly is needed (parts-wise) to do it right.
04-13-2015, 04:12 PM | #11 |
HTCC Member
Heat shields are up to you, but other than that nothing else is needed. you will reuse the bolts that you take off. I would get a plastic trim removal kit, they are about 6 bucks at harbor freight
04-13-2015, 04:18 PM | #12 |
Yea, consenus seems to be the heat shields are not needed, especially since the 1LE doesn't have them and it ain't meltin'
Thanks for the info |
04-13-2015, 05:39 PM | #13 |
Drives: 2015 Camaro 1LE Join Date: Jul 2010
04-13-2015, 07:11 PM | #14 |
HTCC Member
Looks like they are trying to sell you a lot of parts you don't need.
