08-22-2013, 01:40 PM | #1 |
Senior Camaro Fanatic
Drives: 2011 SS/RS manual - White Join Date: Aug 2010
Do I have a header leak?
Pretty dumb question here, but is all the random tweeting and chirping normal for Kooks headers and hi-flo cats on these cars? To me it's just the headers making noise. This is at low RPM and when starting to accelerate.
I actually did have a slight leak when I installed them. That was quite obvious and I put new gaskets on. That constant little pop pop at the flange went away. Just making sure I'm good and not driving around with a problem that still needs attention.
Former '68 and '69 Z/28 Owner...........Now sporting around in a 2011 RS/SS with........Kooks LT's and cats, JRE tune, CAI, scoop, ZL1 Bumper conversion, custom ZL-1 grille, halo harness, Painted silver stripes, GM GFX, black painted lower edge of skirts and rear bumper. MGW shifter.....and now a 3.91 1LE diff
08-22-2013, 02:55 PM | #2 |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Headers definitely do sound different under the engine bay than the stock cast manifolds.
Post up a youtube video or something. Or. Suck a bit of seafoam into the intake and see if you get any smoke under the hood - then you'll know for sure if you have a leak. lol |
08-22-2013, 03:26 PM | #3 |
From my understanding you would have black soot around the area of the header that is leaking. You will be able to hear much more valve train noise with headers. I do.
08-22-2013, 04:06 PM | #4 | |
Geek
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
08-22-2013, 04:12 PM | #5 |
Geek
Assuming yours is the same, I can tell you what I've tried already.
1) Ran it without the catback to eliminate band clamps and rubber hangers. 2) Put the stock air box back in to eliminate my fastlane. 3) Replaced the header gaskets 3 times. There is no leak there. 4) Went all over the engine with a stethoscope... it's almost certainly coming from the exhaust somewhere. 5) Added high-temp RTV to the collector -> connection pipes connection. 6) Pulled the valve covers to check the rockers. 7) Pulled the intake manifold to look at cam lobes to help eliminate lifters. Here is my thread on the issue. You may have already stumbled across it. http://www.camaro5.com/forums/showthread.php?t=296944
08-22-2013, 04:30 PM | #6 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Bump for Chirps! Lol
08-22-2013, 05:07 PM | #7 |
come find out;)
Drives: stockish 2012 camaro ss Join Date: Oct 2012
Squeakkk is back!!! Lol
08-22-2013, 05:21 PM | #8 |
Geek
Haha. As you can see OP... We have discussed this a LOT. It's not normal and we never figured it out.
08-22-2013, 05:28 PM | #9 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
I have Kook's and no squeaks but I use anti-seize (Cop-Graf) on the ball & socket connections themselves. Acts as a lube a bit. Might help. Might be your collars moving around some also, try some under their contact points on the pipes.
08-22-2013, 05:30 PM | #10 |
Geek
How long can i idle my car safely with no O2 sensors Iam broke? I want to eliminate the connection pipe joints too.
08-23-2013, 08:02 AM | #11 | |
I feel better now. The circumstances are exactly like thahemp said. In discussing the first leak and obvious leak with Ted Jannetty, he said it was "imperative that I fix the leak ASAP" That left me nervous as to whether I still have a leak. One comment above addressed the ball joint. I actually think this is the area the "squeak" "tweet" is coming from. It sounds more under the car than in the engine bay. I kinda suspect it has to do with the transition of the air into that goofy looking mesh in the cat. Thanks for the info
08-23-2013, 11:04 AM | #12 |
Geek
Be sure to post if you figure it out. I have TSP headers with slip-joint catless connections. There's a whole lotta wtf in your future .
09-16-2013, 12:16 PM | #13 |
Geek
Did you figure your chirp out yet? I ran open headers last weekend to eliminate the rest of the exhaust connections. It still chirped.
09-16-2013, 01:29 PM | #14 |
Installed my Kooks a couple of weeks ago, and I am hearing the same thing, just beginning to wonder if this just normal for headers. I can't seem to find any leaks or anything BAD.
1969 SS: SS/DA 427 CI/Auto
2011 SS-2 LS3 M6 MODS: P1X ProCharger, Squash dual fuel pumps, ID fuel injectors, Cam: Pat G designed/EPS Ground (228/234 .629”/.629” 114 LSA +4 advance), Lethal Racing ported throttle-body and intake manifold, Kooks 1 7/8” Long Tube Headers, Dynomax Bullet Cat-Back System, Skip Shift Eliminator |
