Old 11-25-2013, 04:27 PM   #1
oachalon
Drives: 2010 Camaro 1SS
Rear Seat Removal
I am trying to remove my rear seat to start my winter project of installing my leather covers.
The bottom cushion was simple, pull up and remove. The back part is giving me tons of trouble. I know you have to pull back the spring loaded retainer clip back and then pull up on the seat. it doesnt matter which position i have the seat back, all the way down, all the way up, 45 degrees, etc i cannot get the seat to pop up off that bracket. Do any of the pins need to be removed or something.
Anybody can help it would be useful.
Thanks,
2010 1SS/RS LS3 M6
Edelbrock E-Force Supercharger, 3.00" Pulley, Roto-Fab CAI, Stainless Power LT Headers, LPE Dual Fuel Pump, ID850's, Custom Grind Cam, Katzkin Leather/Suede Interior 630RWHP mustang dyno.
oachalon is offline   Reply With Quote
Old 11-25-2013, 04:34 PM   #2
SinisterEcho
SinisterEcho's Avatar
Drives: 2010 2SS/RS M6/LS3
Last time i messed with mine, I noticed 2 bolts on each corner that allowed the backrest of the seat to pivot. I would check there.
My Mod Journal <-- Its updated... again!
SinisterEcho is offline   Reply With Quote
Old 11-25-2013, 05:44 PM   #3
oachalon
Yeah, i see the bolts, but do they need to come out? I figured the entire seat pops out from the top of those grooves without removing any bolts.
i could be wrong.
2010 1SS/RS LS3 M6
Old 11-25-2013, 05:46 PM   #4
SinisterEcho
I didnt notice any grooves. I could be wrong though. Ive always just pulled the bolts....
Old 11-25-2013, 05:46 PM   #5
ZeuSS2011
ZeuSS2011's Avatar
Drives: Black 2011 2SS/RS / Black 2013 ZL1
3rd and 4th pics show you how to remove the back rest. If I remember correctly, you may have to lift up on the back rest just a bit to get it to come out . That's with the back rest in the down position.
http://www.camaro5.com/forums/showthread.php?t=123352
ZeuSS2011 is offline   Reply With Quote
Old 11-25-2013, 06:49 PM   #6
oachalon
I have done this. i have both clips all the way down. I tied them off because its only me doing it. I have put as much force as i can and this thing will not come out.
2010 1SS/RS LS3 M6
Old 11-25-2013, 06:57 PM   #7
oachalon
I am about to just get out the impact and take the bolts out and remove the entire assembly.
2010 1SS/RS LS3 M6
Old 11-25-2013, 07:03 PM   #8
Leazimong
Drives: 2014 Camaro 2SS
If you look at the 4th picture with the finger, you'll notice that there is a black plastic grommet/clip type piece where the seat is. You have to make sure that it doesn't turn and that it stays in open like in the picture. Of course the seat has to be tilted correctly also otherwise it won't come out.
It's a big balancing act of tilting correctly and having the black clip aligned so that it comes out. Once you get one side out, just move it a bit down so that it doesn't hook back in when you try to remove the other side.
Leazimong is offline   Reply With Quote
Old 11-25-2013, 07:11 PM   #9
Leazimong
For your visual aid. Oops, badly written, but you get the picture.
Old 11-25-2013, 07:21 PM   #10
oachalon
Update:
i unbolted the entire assembly. The black plastic is completely turned on both sides and keeping the seat from coming apart from the frame. Now i can remove the seat from the frame in my house and bolt the frame back in.
2010 1SS/RS LS3 M6
Old 11-26-2013, 09:15 AM   #11
Knockoutpie
Knockoutpie's Avatar
Drives: 2014 2SS RS Coupe
Originally Posted by oachalon View Post
Update:
Lol, you did so much more work than needed....
Takes 1 minute to pull the entire back seat out. Alone...
Knockoutpie is offline   Reply With Quote
Old 11-26-2013, 12:15 PM   #12
oachalon
Usually that is the case. After removing the assembly and placing it on a bench out of the car it took another 10-15 minutes to separate the seat from the main frame. The passenger side came right out in 2 seconds, but the drivers side still would not. I even made sure the plastic bushing was not in the way. For whatever reason the drivers side tolerances are way too tight. I had to use some pliers, pick tools and a few small pry bars to get that side to finally come out. No way it would have come out in the car.
Usually you just pull back the spring locks and pull up and it comes right up, but mine did not. Could have been temperature related as it was maybe only 25 degrees inside the car.
2010 1SS/RS LS3 M6
