11-13-2013, 06:48 PM | #1 |
Drives: Black Camaro 2SS/RS 1LE Join Date: Jun 2011
ZL1 Front Wheel Air Deflector part #
Does anyone know the part number for the front wheel air deflector for the ZL1? These are the pieces that fit on the "front" wheel well and direct air away/around the wheel.
I want to put them on my 2013 1LE (I like the look ), but I'm not sure it will look right because the 1LE splitter doesn't end flush with the wheel well (so the air deflector will need to be bent). |
11-13-2013, 07:13 PM | #2 |
Just ordered a set. If you Google the part number a bunch of GM sites come up selling it but I just had to find one that would ship via Canada.
Part # 22757643
Todd in Vancouver
'14 ZL1 Camaro '67 Camaro SS Pro-tour in process How hard can it be... Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession |
11-13-2013, 07:16 PM | #4 |
Let's go Rangers!
Yes. In the process of ordering a set from Maureen.
Sent from my 2SS/RS |
11-13-2013, 08:52 PM | #5 |
Drives: 2017 ZL1 Join Date: Aug 2009
My ZL1 didn't even come with them....I wonder why..
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY https://youtu.be/Lcu41obbTf8 '13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight. http://youtu.be/yggIA3C_kkA 2014... back to stock http://youtu.be/spQLaTWbThs 2013... stock & RotoFab |
11-13-2013, 08:56 PM | #6 |
I used to be Dragoneye...
Your Z didn't come with the little bit of plastic riding up front of the wheel well shown in this picture?
11-13-2013, 09:06 PM | #7 |
Reaper Crew
Drives: Blown 2010 Camaro SS Join Date: Aug 2012
Post some pictures when you install them....curious what they look like on the SS bumper..
2010 Camaro SS SLP TVS2300 Blower, Blower Cam, Lingenfelter Heads, Meth Injected, 5lbs of Boost@700 BHP Pedders XA Coilovers |
11-14-2013, 12:40 AM | #8 |
There is a whole thread full of this very topic. Read this and go yell at your dealer if you bought it new.
http://www.camaro5.com/forums/showthread.php?t=195588
Todd in Vancouver
11-14-2013, 03:30 AM | #9 |
No it didn't. I was at the dealership last night and noticed 1 out of the 5 ZL1s didn't have it either. Ironically, it was the one the same color as mine.
11-14-2013, 07:50 AM | #10 |
Go back. Go get them...they are a part of the ZL1's aerodynamic package...should have been on from the factory - and the dealer should have noticed they were missing.
11-14-2013, 09:47 AM | #11 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Just to be clear, there are two little (I call them winglets) that mount in front of each front wheel UNDER the front of the car. Look carefully in the picture in front of the front tire at the BOTTOM of the car.
NOT the leading edge 'mud flaps' in the front wheel well opening. The 'winglets' are items that the dealer is supposed to install as part of PDI along with removing the front spring spaces. If you see a ZL1 in the lot, it may or may not have already gone through PDI so the winglets may not have been installed yet. The leading edge 'mud flaps', I have no idea but I would assume THEY should already be on the car. |
11-14-2013, 10:34 AM | #12 |
Drives: 2017 Bright Yellow ZL1 6spd Join Date: May 2010
11-14-2013, 10:36 AM | #13 | |
11-14-2013, 10:37 AM | #14 |
Turns out we were talking about two different things.
I call the "forward mud flaps" air deflectors....and the pieces under the fascia: "air dams". Whoops! |
