Old 07-11-2011, 02:16 PM   #1
orangejuice
H1 OFCR
orangejuice's Avatar
Drives: 2013 ZL1 Blue Ray Metallic
Camaro Emblems
Hey guys, since I've joined the forum, I have seen a ton of Camaro's with added emblems. If you have added emblems, can you tell me where you got them from? Thanks guys!
orangejuice is offline   Reply With Quote
Old 07-11-2011, 02:19 PM   #2
The_Bosnian_Synergy
The_Bosnian_Synergy's Avatar
Drives: 2011 Synergy Camaro
Mine was a sticker from www.bigwormgraphix.com
The_Bosnian_Synergy is offline   Reply With Quote
Old 07-11-2011, 02:21 PM   #3
Spencer@EH
Spencer@EH's Avatar
Drives: 2010 Yellow RS
I got mine from EmblemPros! Excellent customer service! Would definetly buy from Roger again.
Spencer@EH is offline   Reply With Quote
Old 07-11-2011, 02:26 PM   #4
angie7
Smoked by a GIRL
angie7's Avatar
Drives: 2014 2SS/RS
I ordered my custom color match bowties thru RPI designs. Very good quality!
2014 2SS/RS Summit White w/ IOM interior "Powder 2.0"
angie7 is offline   Reply With Quote
Old 07-11-2011, 02:31 PM   #5
orangejuice
H1 OFCR
Has anyone painted there taillight bezels a flat black? I want mine flat black and refuse to pay $150-$200 for a cheap piece of plastic, I was thinking about painting them myself. Any tips or kits out there?
Old 07-11-2011, 05:30 PM   #6
1COR.1:18
Whosoever Will
1COR.1:18's Avatar
Drives: 2010 1LT Victory Red
look in the DIY section, bought a set used for $15.00 PLUS $8.00 in paint and sandpaper. They turned out great.
http://www.camaro5.com/forums/showthread.php?t=110646
1COR.1:18 is offline   Reply With Quote
Old 07-11-2011, 05:32 PM   #7
Mustang Killa
Mustang Killa's Avatar
Drives: Black 2SS
emblems from jaison @ thirdshiftstudios.com they turned out MUCH nicer than the SLP badges
Mustang Killa is offline   Reply With Quote
Old 07-11-2011, 05:54 PM   #8
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
I had showstopper paint mine for $100. His work is perfect and he puts on several coats of clear. I've learned that quality paint work is well worth paying for.
On the other hand, if you feel confident doing it yourself, then have at it. Sand them, use adhesion promoter, paint them, and use at least 2 coats of clear.
Old 07-11-2011, 07:13 PM   #9
GreenMonster
Its all about the U
GreenMonster's Avatar
Drives: 2010 SGM
plastidip$5 a can no need to sand just spray .. if you dont like it/get tired of it just peel off
GreenMonster is offline   Reply With Quote
Old 07-11-2011, 08:15 PM   #10
Augie1978
Augie1978's Avatar
Drives: 2011 2SS RS Vert
Should have added this along time ago. Got it at Sparksrestoration.com.
2SS RS, Triple Black Vert, Manual, Hurst Shifter. American Racing Headers, Roto-Fab CAI
Augie1978 is offline   Reply With Quote
Old 07-12-2011, 09:52 AM   #11
orangejuice
H1 OFCR
Thanks guys!
Old 07-12-2011, 11:42 AM   #12
camaro52010
Camaro4ever
camaro52010's Avatar
Drives: 2010 Camaro SS/RS, 1978 Z28 Camaro
www.classicautoemblems.com www.emblempros.com www.sparksrestorations.com
camaro52010 is offline   Reply With Quote
Old 07-12-2011, 12:02 PM   #13
scythezo6
Virologist in the making
scythezo6's Avatar
Drives: 2010 VR SS/RS LS3
That's what I got on mine. Very good quality product. I absolutely love it.
Old 07-12-2011, 02:14 PM   #14
Don57
Drives a beast!
Don57's Avatar
Drives: Yellow 2014 Camaro 2SS/RS
I'm in the process of re-painting mine. I didn't sand them down well enough the first time -- I used too-fine sandpaper and did not do a thorough enough job -- and the primer eventually started flaking off.
I've been resanding the hell out of them with 60 grit sandpaper (had to get the bits of primer that *did* stick off again) until they no longer shine. Someone recommended to go with only 200 grit or so, but I found the coarser grit to work better.
There are lots of nooks and crannies on the inside that can become starting points for flaking if they're not sanded -- those are a bitch to rough up.
The goal is to sand until they look like dull brushed-metal. I've spent about an hour per bezel so far just sanding them (one more to go!), though I have the added work of getting the previous paint/primer job off, too.
Someone else on the forms recommended using self-etching primer, too, which I didn't use the first time.
Hopefully it will turn out nicely this time. I love the way they look painted flat black, and I've been putting a lot of elbow grease into scuffing them up for priming...
Don57 is offline   Reply With Quote
GT5 Camaro pics brantley847 Camaro Photos | Spyshots | Video | Media Gallery 93 05-27-2013 08:35 PM
Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS CamaroScotty 5th Gen Camaro SS LS LT General Discussions 338 04-15-2009 05:33 PM
