03-17-2017, 09:46 AM | #1 |
Drives: 2013 Camaro ZL1 Join Date: Feb 2017
ZL1 Boost plus Nitrous Question
Hello, I have a 2013 ZL1 with Headers, CAI, and Nitrous outlet LSA/ZL1 Plate system installed. I am getting ready to remove the super charger to replace isolator/coupler and I need some advice. I am wanting to replace the lower crank pulley and I would like to get as much power as possible. I would like to do the 28% lower pulley and idler relocation bracket and upgrade the injectors to ID850. My worries is can I run this combo and still be safe on the bottom end of the vehicle. My nitrous system is set with the 100 HP jets installed currently. Please advise.. I know once I get done the vehicle will have to be custom tuned again which I plan on getting done once vehicle is back together. I am also running Iridium Denso IT24 plugs right now as well... I really want to hear all advice and suggestions
2013 ZL1 Camaro 5.100 miles. Stainless Power Long Tube Headears, Airaid Cold Air,JRE Rough Idle Cam Pkg, Injector Dynamics 1050X injectors, 174 Deg. Thermostat, JMS Bap, LSX Concepts 29% Gilmer Drive, Nitrous Outlet Full Intake System. K-40 Radar Detection System... FAASSTT
03-17-2017, 11:24 AM | #2 |
No one here has any thought.. I thought there was a lot more performance gear heads on here... come on
03-17-2017, 02:45 PM | #3 |
Drives: 2012 ZL1 #1329 M6 Join Date: Jun 2009
Check out the CTS-V Forums man. I think you will get your question answered. Those guys take them cars to the next level.
2012 Camaro ZL1 #1329 M6 Summit White
Built by Mike @ Rapid Motorsports 784rwhp 757 rwtq on 93 Octane ET - 10.97 @ 128 Heads-Blower-Snout-TB ported & prepared by Jeremy Formato of FasterProms http://www.camaro5.com/forums/showthread.php?t=395950 Rapid Motorsports 396ci Build https://www.camaro5.com/forums/showt...1#post10321301 10.832 @ 130.99 |
03-17-2017, 03:25 PM | #4 |
We would recommend some other mods to go with it to keep the boost levels safe. We see you already have headers but you might want to consider a cam upgrade. Other mods to keep the intake temps down such as a bigger heat exchanger or a intercooler pump upgrade would help out too. You will also want to upgrade your fuel pump too if you haven't already.
03-17-2017, 03:42 PM | #5 |
I don't agree with the fuel pump- Factory ZL1 pump should be sufficient from what I've seen.
03-17-2017, 04:16 PM | #6 |
Drives: 2014 ZL1- Summit White M6 Join Date: Aug 2014
The 28% is the 10" pulley correct? If so I would run the 10.5" stock upper
Change out your plugs to NGK7s Dedicated fuel cell, I wouldn't trust pulling from the rail anymore after the pulley swap
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
03-17-2017, 04:27 PM | #7 |
Were you running it with nitrous before the tear down? What did your WOT AFR look like at, say 5500 RPM? The 28% is overdriven, correct? How much boost will that add? I know you will gain some head room with the increase in injector size, but I'm not sure it will be enough to support the increase in boost plus the 100HP shot of nitrous. I'd hate to see you run lean at the top of the RPM scale under boost w/nitrous.....catastrophic.
-Scott |
03-21-2017, 12:58 AM | #8 |
"BEASTM*DE"
If you don't increase your fuel you're going to blow your motor...But it seems you already have it figured out and really don't need our info, so go ahead with your plan...I doubt that you would get a reputable tuner to put it on their dyno without having to sign a waiver...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
03-21-2017, 11:08 AM | #9 | |
Drives: Fast Join Date: Mar 2015
OP, you can only add so much boost before wasting it and you'll need a cam with a 10". Also your temps with a 10" is going to be WAY out of the stratosphere with no additional cooling measures such as Meth, E85, or a HX upgrade. No the nitrous is not enough to cover it. If you want to do a 10": Cam Boost-a-pump for fuel ID850s or 1050s Heat Exchanger And you probably should add a flex fuel sensor and put it on E85 or a 50/50 E85/93 mix. If you want to stay away from a cam, then do a 9.1" lower pulley (18%), which is pretty much the max you can run without crazy IATs and without needing a cam. ID850s are fine for that on 93 and you probably won't need a BAP at 18%. Nitrous should cool you enough too. Don't take our word for it though, call some shops and go with your plan. |
03-21-2017, 05:48 PM | #10 |
Don't claim to know everything....
I by no means am trying to dispute anyone's advice. I looked at my original post and yes you are correct with a 28% pulley I would need to do something different. I think I am going to stick to a 18% pulley- id-850 injectors and the 100 hp shot of nitrous. I will be adding a voltage booster for the fuel pump but I think I should be pretty happy there. I don't know are we ever happy... lol
03-22-2017, 01:25 AM | #11 | |
"BEASTM*DE"
03-22-2017, 08:07 AM | #12 |
Drives: 2015 camaro 2lt Join Date: Dec 2016
do the cam even a mild cam will help and sound nice
Cosmetic mods: SS hood with painted vent, SS bumper, acs 1le front lip black, big worm gfx tinted all lights, solar wing v2, Camaro seat belt pads and oracle color shift halos and fog light halos and rear colorshift bow tie, carbon creations carbon fiber stingray z spoiler
Wheels: lexani r-3 bg finish 19x8.5 Performance: cold air inductions intake, mrt v1, jacfab ported intake manifold, intake manifold spacer, overkill tuned on E85. |
03-22-2017, 09:00 AM | #13 |
Get Injectors.
03-28-2017, 06:25 PM | #14 |
Future Mods to the car.
At this time I am going to go with the 10' crank pulley and ATI balancer. I will do the idler relocation bracket and new belt. I am doing the ID850 injectors and will be doing the BAP module. 174 deg thermostat and Roto-Fab Carbon cold air Intake. I want to do a Cam but I have not decided which one I am going to go with yet. advice would be welcome. With that being said that Brings me back to the Nitrous Issue I think I will mainly keep it on the car for Purging and show purposes only but didn't know If I would still be able to run a 50-100 shot or If I would be out of fuel at that time. Don't know how much overhead. Ted Jannetty thought I might still be able to do a 50-75 shot but wasn't sure.
Thanks to all for any advice on cam- Thinking of Jannetty rough idle cam?
