03-31-2014, 09:16 PM | #1 |
Drives: '12 2SS/RS 45th vert, '14 2SS/RS Join Date: Nov 2013
Tonneau Cover
I keep trying to use this tonneau cover because I've been told that the top will wear out prematurely if I don't but I HATE this thing!!!
I am constantly having to watch my rear view mirror to see when it is coming loose. At highway speeds, I have to pull over every 20 minutes to put it back on because it has blown loose except for the two elastic straps. Surely someone must have a solution for this thing. |
03-31-2014, 09:19 PM | #2 |
Lifetime Philly Fan
Drives: 2015 Spring Edition 2SS M-6 Join Date: Mar 2012
Just don't use it. Whoever told you that is wrong. Are you putting it on right, tucking in the front of it behind the seat? I have never had any problem with mine and that includes hauling ass down the interstate at 90 mph.
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter BBK LT HEADERS 1 7/8” Tune by DynoSteve via SCTx4 Tuner One of 82 GF Ragtops built in '15 out of 811 Total [/SIZE] |
03-31-2014, 09:32 PM | #3 | |
And when I'm talking about highway speeds, I'm referring to like 65mph. |
03-31-2014, 09:42 PM | #4 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
Never had an issue with mine either....
The Bird is the word! |
04-01-2014, 12:44 AM | #5 |
Drives: 2011 IOM 2SS/RS M6 Convertible Join Date: Feb 2014
Our car never had the bolts installed by the previous owner, so i assume he never used the tonneau... I added the bolts and have been using it every time we have the top down, had it up to about 110 and it just barely ripples, never had it come loose.
I do lay a folded bath towel over the top before putting the tonneau on, saw that trick mentioned by someone here. It keeps it from rubbing the top, and makes it fit a bit tighter. Its a bit of a hassle but i love the look.
04-01-2014, 02:05 AM | #6 |
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH Join Date: Jan 2014
Here's a couple of ideas for you. First is a simple DIY thread to add extra tie downs:
http://www.camaro5.com/forums/showthread.php?t=272309 The other thing I plan to do is utilize an "interior cover" whenever possible so I am not always putting the top up and down. So once you get that tonneau nice and secure, you can leave it in place. Just be aware that long term storage in the down position will increase wrinkles temporarily. http://www.carcoversdirect.com/parts...3380/materials
Consensus is, by definition, a lack of leadership.
04-01-2014, 12:26 PM | #7 | |
"Katy"
Drives: 2014 2LT A6 'Vert Join Date: Feb 2014
2014 Black 2LT Convertible
Elite Engineering Catch Can, Vitesse Throttle Controller, CAI Cold Air Intake Possible next mods: Throttle Body Exhaust Upstate C5 Member No, that is not me in the avatar..... I just love hot girls and hot cars.... or hot girls IN hot cars.... |
04-01-2014, 01:09 PM | #8 |
Drives: 2016 2SS Convertible Join Date: May 2012
This isn't the best illustration, but your tonneau cover should have the bungee cords that attach to posts as shown here:
http://sandyblogs.com/techlink/?p=381 If your car doesn't have the posts behind the back seats and your cover doesn't have the bungee cords as shown then contact a dealer. As others have said I haven't had any issues with my cover even when passing other cars and trucks on the interstate. I don't know that it makes any difference for the cover coming loose, but I also use a thin black microfiber towel between the convertible top and tonneau cover to prevent the cover from leaving rub marks on the convertible top. |
04-01-2014, 04:15 PM | #9 |
Drove over 200 miles today with mine on at speeds up to 75 on the Interstate, no problems at all with it staying put. It wiggled some when I passed some 18 Wheelers but that is all.
04-01-2014, 06:02 PM | #10 | |
It's really strange that some stay on fine while others blow off constantly. I wonder if there's a pretty wide variance in manufacturing or something about the sequence we use to put them on? I've read a ton of old threads here, especially in the convertible forum, before buying a 2011. One of the issues I expected to have to put up with was the tonneau since '11's have the old design... but I've pretty thouroughly tested it and I just can't see this thing blowing off
04-01-2014, 06:10 PM | #11 |
Drives: 2011 2SS Convert; Color RJT Join Date: Sep 2009
Mine has blown "loose", but not completely off. In post #20 I mentioned how I fixed the problem! Good luck.
http://www.camaro5.com/forums/showthread.php?t=307693 |
04-01-2014, 06:44 PM | #12 |
Drives: 13 zl1 crt convertible Join Date: Aug 2013
I've noticed by pictures on some forums that there seems to be two styles of covers. some have a flap in the front that you tuck in. mine has flaps on the front & rear that you tuck in.
04-01-2014, 06:54 PM | #13 | |
I'd love to compare a few of these side by side, especially known good ones and known to blow off ones. Mine has the 4 or so " flap that folds down in the front, the back just sticks straight back under the trunk lip. Since I bought the car used, I don't know for sure but I assume its the original design, car built in April 2011.
04-01-2014, 07:03 PM | #14 | |
