Old 09-18-2018, 08:27 PM   #1
moiy1983
moiy1983's Avatar
Drives: 2010 camaro ss/rs
LSA Conversion
Whats all needed besides blower & heat exchanger? Can I use my ls3 brackets & accessories???
2010 SS @gt_klr Built by Jrod Tuned by Matt Sorian
LSX 434 by HKE Dragon Slayer, Callies ultra rods, Wiseco Coated Pistons, Mast 285cc LS7 Heads
ProCharger F1-X
Nitrous Outlet Direct Port
Fore Innovations Triple Pump on E85
Alky Control Meth Injection
ProEFI ECU
Stainless Works 2" Headers with Corsa 3" Exhaust
RPM 4l80e with Jakes Transbrake
BMR Everything with 15" Conversion
Zl1 Front Brakes & Carlyle Racing Rear Brake Kit
Weld Wheels
moiy1983 is offline   Reply With Quote
Old 09-18-2018, 09:19 PM   #2
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
No need to reinvent the wheel..Buy a kit. It'll have what's needed...tuner kit comes without injectors or tune....full kit has it all. Various types in the classifieds here.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 09-19-2018, 01:20 PM   #3
schul274
Drives: 2011 Camaro SS2RS, 1970 Camaro SS
https://www.camaro5.com/forums/showthread.php?t=456603
Here is my budget build and prices for everything. Don't think you can get much cheaper.
schul274 is offline   Reply With Quote
Old 09-25-2018, 01:39 PM   #4
Blown2013SS
Drives: 2013 2SS convert
If you do it the cheap way and re use your LS3 brackets and pulleys you end up with a 6 rib belt running the blower instead of the 8 rib belt that the LSA used. Works fine for low boost, high boost the belt will slip. I chose to use all ZL1 drive components to keep the 8 rib belt. most of the brackets and pulleys are different. I also had to replace the A/C compressor, A/C hoses, condenser and the alternator. I currently run 12 psi boost with no problems.
Blown2013SS is offline   Reply With Quote
Old 09-25-2018, 03:01 PM   #5
ticowarbird
BOHIC
ticowarbird's Avatar
Drives: 2010 Camaro SS "Enola"
If you're feeling lucky you could check out this post on Instagram. @2015_camaro_1le
What else can I do to my Camaro?
ticowarbird is offline   Reply With Quote
Old 09-26-2018, 11:35 AM   #6
schul274
That's actually the kit from the budget build link I posted. I sold it to him, he never installed it, and is raffling it now.
