Old 06-15-2016, 09:15 PM   #1
schul274
Drives: 2011 Camaro SS2RS, 1970 Camaro SS
Budget LSA Install
I purchased an LSA supercharger off craigslist last summer thinking it could be easily installed and retuned for a reasonable amount of money. After starting to research it I found that even with a base kit and tune I could be into the 4k range.
I found a number of peoples forums who had installed the kit as well as looking at ADM's kits to see what was needed. Over the last 6 months I purchased mostly used parts to put the kit together myself. In the end I spent roughly 3500 for everything including the tune. All work was done myself so I saved on that.
Component-actual paid-Where I bought
supercharger-400 -cl
ZL1SUPERCHARGER LID-180 camaro5 (bought a CTS-V lid to save money)
SUPERCHARGER GASKETS-came with charger
LID GASKET-came with charger-came with charger
supercharger bolts-30-adm
WIRING FOR IC PUMP-20-made
BOSCH INTERCOOLER PUMP-50-ctsvowners (ctsv pump)
PUMP BRACKETS-w/ pump
LSA HEAT EXCHANGER-80-camaro5
ADM IDLER BRACKET-250-Craigs list
BELT (K061005 )-20-amazon
PRE MADE INTERCOOLER HOSES-Just bought stock gates hose
RESIVOIR AND BRACKET-45-cts-v reservoir (amazon)
LS9-LSA INJECTORS-100-ls9 injectors craigslist * not big enough
LSA FUEL RAIL-240-ebay
ZL1 FUEL LINE-10-auto part store gates fuel injector hose
EVAP SENSOR PIPE FOR ZL1-using std hose
EXTENSIONWIRE FOR THROTTLEBODY-made
MAP SENSOR-30-amazon
EVAP SENSOR-40-amazon
SOLDER AND HEAT SHRINK
LSA TENSIONER-200-adm
LSA TENSIONER BRACKET-68-adm (ebay for bolt)
Fuel Pump and adm fpcm-350-camaro5
Spark plugs-55-ctsv forum
tune-720-late model throttle
cam-95-covette forum
cam install kit-100-adm
2.75 Pulley-150-adm
Intake-75-made/amazon
Total(with odds and end not listed =3500
to this
I took lots of pictures so I'll work on getting those up as well.
Final numbers were 575/540
schul274 is offline   Reply With Quote
Old 06-15-2016, 09:20 PM   #2
failshift
Banned
Definitely unique.
LSX376 SLP TVS2300 '13 1LE
Full front half protected by Xpel PPF
Instagram:@Failshift
625hp/582tq
1LE Owners Group:
https://www.facebook.com/groups/559684050767758/
failshift is offline   Reply With Quote
Old 06-15-2016, 09:27 PM   #3
Splat
Splat's Avatar
Drives: 2012 1SS M6 IOM
Not a huge fan of the orange.... but thats just me.
Nice numbers, did you install a cam as well?
2012 1SS Camaro LS3 Inferno Orange
Mods: LSA Supercharger, 2.55 Pulley, Custom Boost Cam, ARH LTH 1 7/8, HFC, 3' Magnaflow Exhaust, JLT CAI, Elite CC V2, BO White Stage 2 TB, GM 3.91 Gears, DSS CF Driveshaft, BMR Bushing Kit.... . Tuned by JTM Motorsports 540 Hp 550Tq on 9PSI
Axles, Monster Clutch, Hotchkis TVS Track Pack kit.......For 2018.
Splat is offline   Reply With Quote
Old 06-15-2016, 09:40 PM   #4
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
+1 on the orange, but to each their own...
That's a ctsv lid, not a zl1. Great numbers for the investment
ttshovel is offline   Reply With Quote
Old 06-15-2016, 10:24 PM   #5
schul274
It ended up a little more orange than I intended, but I have the inferno orange interior so I wanted thay in the bay.
I'll edit the post for the lid. The original list had a zl1 lid, I bought the CTSV lid because it was cheaper
Sent from my SM-G935R4 using Tapatalk
Old 06-15-2016, 10:40 PM   #6
schul274
I did put an LS9 cam in with this install.
Old 06-15-2016, 10:52 PM   #7
schul274
Old 06-15-2016, 11:53 PM   #8
hammdo
'It's an experiment'
hammdo's Avatar
Unique and nice numbers!
Great work with the budget too! You'll love the LSA setup!
-Don
747 RWHP 794 RWTQ
Old 06-16-2016, 01:30 AM   #9
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
Looks like spaghetti
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 06-16-2016, 03:56 AM   #10
avido
Drives: camaro ss\rs
why is there that drop in the torque and not in the power?
2014 camaro SS Whipple powered ,3.750 pulley,ID850, CAI,Flowmaster American Thunder exhaust,MGW racing shifter,Bo White ported tb,MightyMouse Catch Can,Vitesse throttle controller,GM 3.91 rear end, Dynatech longtube haders, BTR Pd cam,Fluidampr stock pulley,ZL1 fuel pump and ADM fpcm, Phastek scoop and fluid thank relocation Bmr Motor mount . Tuned by Mastuning
avido is offline   Reply With Quote
Old 06-16-2016, 12:42 PM   #11
Dgnelson2
Dgnelson2's Avatar
Drives: Camaro 2SS 1le
Not very familiar with dyno grahps and what one with this setup would look like, but that drop off in the middle then it come back has me wondering.
Dgnelson2 is offline   Reply With Quote
Old 06-16-2016, 12:53 PM   #12
schul274
It's just a bad reading. If the torque had really dropped the HP would have as well since HP = Torque x RPM χ 5252
Old 06-17-2016, 09:40 AM   #13
supergt99
supergt99's Avatar
Drives: 2013 Camaro SS 1LE
congrats. nice numbers. i have the same setup but didnt dyno mine. definitely fun to drive.
supergt99 is offline   Reply With Quote
Old 08-12-2016, 08:20 AM   #14
Mrbowtie26
Mrbowtie26's Avatar
Drives: 2015 CRT 1SS 1LE
Why paint the heat exchanger lol
Mrbowtie26 is offline   Reply With Quote
