Old 03-20-2012, 02:02 AM   #1
Mustang Killa
Mustang Killa's Avatar
Drives: Black 2SS
Will the ZL1 font end slow you down with out the hood? (create lift)
The front end is designed in conjunction with the hood to create downforce instead of the lift created by the front end of the V6 or SS.
If you have the front end directing the air up and then getting trapped under a non Zl-1 hood won't it create more lift?
Im no physicist but by looking at the wind tunnel videos, if you add the front end to your SS or V6 that air will need somewhere to escape..
Mustang Killa is offline   Reply With Quote
Old 03-20-2012, 05:55 AM   #2
radametz
radametz's Avatar
Drives: 2013 CRT 2SS/1LE; 2016 Colorado Z71
I don't know how much lift it will generate, but I'd have to imagine it would generate some. Every aspect of the ZL1 was designed to work with each other, and the hood extractors (like you said) funnel that air coming from the front grille out from under the hood. Without those extractors, the air has a much smaller area to escape from and will generate some lift. How much lift it actually generates? your guess is as good as mine
radametz is offline   Reply With Quote
Old 03-20-2012, 06:23 AM   #3
Russell James
Russell James's Avatar
The SS or LS/LT isn't going to hit speeds that it matters, unless highly modified. And if it gets modified that much, I doubt a ZL1 front will be the only body mod.
99.999999% of the people doing a mod like that is for looks only. Plus they probably aren't putting on a belly pan, so plenty of open areas for underhood air to go.
Old 03-20-2012, 09:27 AM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I believe the downforce on ZL1 is something like 60 pounds @ 150 MPH, or something along those lines. How much the hood adds has not been announced to my knowledge. Because it's not the only element that contributes to the overall downforce, I'm sure it's relatively significant. That splitter air's gotta' go somewhere besides out the wheelwells and brake ducts.
I'd be just as interested in seeing how much the total downforce affects top speed
'20 ZL1 Black "Fury"
Old 03-20-2012, 09:35 AM   #5
midnighter
Drives: nothing
If I ever did the ZL1 body conversion I would at least get both the ZL1 front fascia and the hood. I did get the ZL1 grill. Hopefully my Camaro SS works correctly after it's installed.
Old 03-20-2012, 10:47 AM   #6
dirishboy
as in Irish European
dirishboy's Avatar
Drives: 2012 ZL1
^^^^^^^^^ This
Without the belly pan the front will operate completely differently.
dirishboy is offline   Reply With Quote
Old 03-20-2012, 11:08 AM   #7
Fenderaddict2
Opinionated bugger!
Fenderaddict2's Avatar
Drives: Boss 302, Mazda 2, Praga & Intrepid
If you track your car, subtle things such as the hood extractor design, balance between front and rear aero effects, and such make a notable difference, but if you drive on the street, you won't notice a thing.
Follow me on forums everywhere as Fenderaddict2 or my kid on the track and Twitter @fastmyles
Fenderaddict2 is offline   Reply With Quote
Old 03-20-2012, 12:01 PM   #8
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
If your not going to race it don't worry.
And if you are, it's probably nothing you'd be able to notice unless your traveling at very high speeds.
2cnd chance is offline   Reply With Quote
Old 03-21-2012, 10:20 PM   #9
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Without the full front-end aero packge, the front fascia alone will be detrimental to stability/lift on an otherwise stock SS.
That said...people not planning to race 140+ mph probably don't need to worry much.
Old 03-21-2012, 10:26 PM   #10
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Or you get the hood and insert.
Old 03-21-2012, 10:57 PM   #11
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Should be fine like everyone else stated. Unless your going to go really fast. And at that point your stock hood will fly off and the car will spontaneously combust
CAMARO
Old 03-22-2012, 01:56 AM   #12
Pappa Joe
Pappa Joe's Avatar
Drives: Charger/TL1000R/Cobalt/ZL1
lolz....:bellyrol l::bel lyroll::bellyroll :
Pappa Joe is offline   Reply With Quote
Old 03-23-2012, 11:50 PM   #13
midnighter
Drives: nothing
Good point.
Old 03-24-2012, 12:28 AM   #14
piepouli
Drives: 04 gmc/ zl1
I think all the wind tunnel testing was done with the hood scoop, so I would say ya it would effect it, only noticable at high speeds
piepouli is offline   Reply With Quote
Transcript of Camaro ZL1 Q&A Webchat with Chevrolet Tran Camaro ZL1 Forum - ZL1 Specific Topics 42 12-22-2017 04:42 AM
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
Camaro5Fest III location nomination Atti2de 2012 Camaro5 Fest (III) 2717 05-30-2012 11:59 PM
2012 Camaro ZL1 Price Announced at $54,095 MSRP ! TLSTWIN Camaro ZL1 Forum - ZL1 Specific Topics 735 12-20-2011 08:48 AM
Need help with order please zfuzz Camaro ZL1 Forum - ZL1 Specific Topics 7 11-22-2011 06:40 AM
