Old 09-21-2018, 05:00 PM   #1
Dutchman427
Dutchman427's Avatar
Drives: 2012 ZL1 #1329 M6
Rapid Motorsports 396ci Build
Callies Dragonslayer Crank
Callies Ultra H Beam Rods
Diamond 10.1 Pistons.
Rapid Motorsports Custom Grind Cam "Last Hurrah Grind"
Blower, Snout and heads are still from the old set up ported by Formato.
102mm TB and RPM 5 Inch Intake.
DSX flex fuel sensor and Auxiliary Fuel Pump
2.40 upper 9.55 lower
Active Chiller.
PUMP 93 Tune 801rwhp 804rwtq
Sheetz e85 Tune 855rwhp 854rwtq More like 70%
Big Thank you to Mike for coming out of retirement to get this car where it needed to be!
2012 Camaro ZL1 #1329 M6 Summit White
Built by Mike @ Rapid Motorsports
784rwhp 757 rwtq on 93 Octane ET - 10.97 @ 128
Heads-Blower-Snout-TB ported & prepared by Jeremy Formato of FasterProms
http://www.camaro5.com/forums/showthread.php?t=395950
https://www.camaro5.com/forums/showt...1#post10321301
10.832 @ 130.99
Dutchman427 is offline   Reply With Quote
Old 09-21-2018, 05:52 PM   #2
SCHUSS
709 RWHP & 677 RWTQ
SCHUSS's Avatar
Drives: 13' HPE 800 ZL1..... IOM vert, M6
Awesome!!
11.34 @ 124.88
SCHUSS is offline   Reply With Quote
Old 09-21-2018, 06:36 PM   #3
Dutchman427
Originally Posted by SCHUSS View Post
Awesome!!
Thanks man! Figured I make a post with a different combo.
10.832 @ 130.99
Old 09-22-2018, 07:06 AM   #4
BURNYs
BURN RUBBER NOT YOUR SOUL
BURNYs's Avatar
Drives: 2013 ZL1 M6 Blue Ray
Nice numbers man. I get my E85 from Sheetz in York PA, it tested to be 80%.
Mods-Kong Ported Blower, ID1700X injectors, 2.35/8.65, TSP Ported Heads, Custom Grind Cam, RPM 5 inch Intake, NW 102mm, Kooks 1 7/8, Corsa Extreme, Afco Heat Exchanger, PNR 4 gal ice tank/EMP pump, Oil catch can, Thermal reduction plates, BR7EF plugs, DSX Aux Pump, Monster LT1-S triple. 788hp/757tq-93, 839hp/785tq-E85. Burn Rubber Not Your Soul
BURNYs is offline   Reply With Quote
Old 09-22-2018, 07:13 AM   #5
Dutchman427
Thanks man! Time to get it to the track again. I got mine at the Sheetz in Leesport, PA. That's what it was coming up as. I believe you though!
10.832 @ 130.99
Old 09-22-2018, 08:37 AM   #6
AJensen383
AJensen383's Avatar
Drives: 2014-ZL1-M6-CRT, 68 camaro SS 496
Didnt you have Kong doing some port work??
2014- Crystal Red-ZL1 #1601, M6, Recaro, sunroof, Nav-stock-SOLD
1968 Camaro SS Clone- 496 BBC, Legend 5speed, 12 bolt
1970 Nova SS- 383 SBC 588hp, 200-4r, 12 bolt
AJensen383 is offline   Reply With Quote
Old 09-22-2018, 08:40 AM   #7
Dutchman427
He ported the snout to 102mm. He also did the first tune with the Cam Motion Off the shelf grind cam. All I am gonna say is, nobody tunes like Mikey.
10.832 @ 130.99
Old 09-24-2018, 06:26 PM   #8
ws6mikey
Drives: 99 Trans Am
Your car turned out amazing Andy. Always a pleasure to see you.
ws6mikey is offline   Reply With Quote
Old 09-25-2018, 04:57 AM   #9
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
Strong numbers Andy! I know you are smiling. Have a Blast with that thing.
Congrats Man!
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH
12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD
06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD.
96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH
2NASSTY is offline   Reply With Quote
Old 09-25-2018, 03:26 PM   #10
Dutchman427
Thanks Mike, Appreciate it!!
10.832 @ 130.99
Old 09-25-2018, 03:28 PM   #11
Dutchman427
Congrats Man!
Thanks Chett!
Yeah, the car definitely pulls hard! I would like to get to the track yet this year, but with the work load being the way it is, I don't know yet.
10.832 @ 130.99
Old 09-25-2018, 05:34 PM   #12
owhite3003
Z-BEAST
owhite3003's Avatar
Drives: 2013 JDP ZL-850 Track Spec ZL1,
Sweet.
owhite3003 is offline   Reply With Quote
