Old 07-20-2018, 08:37 PM   #1
PolarBearSS16
Agent Orange
Drives: 2022 ZL1
How different are the 2013 vs 2014 ZL1 superchargers?
I have a 2013 ZL1 and the bearing just went out on the snout pulley and I went down to a Chevy dealer and instead of replacing the snout piece, they were replacing the entire supercharger under the extended warranty. Why not just replace the snout? Is there just a big difference between the 2 superchargers altogether?
PolarBearSS16 is offline   Reply With Quote
Old 07-20-2018, 09:29 PM   #2
SecondZ28
SecondZ28's Avatar
Drives: 2013 ZL1
Chevy only replaced the entire supercharger under warranty. They never just did the snout
'13 ZL1
'06 TBSS
'98 TJ
'87 GN
SecondZ28 is offline   Reply With Quote
Old 07-21-2018, 11:55 AM   #3
TTTAPOUT
Drives: 2013 ZL1
Now that they have replaced the supercharger, go straight to a reputable shop and have a solid coupler installed!
https://www.lingenfelter.com/product...l#.W1NlddJKiUk
TTTAPOUT is offline   Reply With Quote
Old 07-21-2018, 12:19 PM   #4
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
The new one should have a solid isolator, double check it by removing the belt and rotating the snout pulley back and forth.
ZMEnow is offline   Reply With Quote
Old 07-21-2018, 12:32 PM   #5
SecondZ28
SecondZ28's Avatar
Drives: 2013 ZL1
GM stopped putting solid ones in and went back to spring loaded....
'13 ZL1
'06 TBSS
'98 TJ
'87 GN
Old 07-21-2018, 01:29 PM   #6
ZMEnow
Yeah heard this discussion before, do you have the new TSB that show that?
https://www.camaro5.com/forums/showthread.php?t=487501
Old 07-21-2018, 08:14 PM   #7
Wild One
Drives: 13ZL1
My supercharger was replaced last week of May this year has the solid coupler.....
Wild One is offline   Reply With Quote
Old 07-23-2018, 09:46 PM   #8
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
I'm still running the original SC with the spring loaded coupler...several track days... no issue
Mods:
Old 07-24-2018, 08:13 PM   #9
SecondZ28
SecondZ28's Avatar
Drives: 2013 ZL1
There was more info on ctsv. A little info here
https://www.camaro5.com/forums/showt...=524868&page=2
'13 ZL1
'06 TBSS
'98 TJ
'87 GN
Old 07-24-2018, 09:36 PM   #10
ZMEnow
I didn’t see an updated tsb that indicated they are now putting spring vs solid.
Old 07-25-2018, 10:51 AM   #11
SecondZ28
SecondZ28's Avatar
Drives: 2013 ZL1
There is a lot more info on CTSV, as the V2 guys do more upper pulleys than ZL1 for some reason. Starting around 2015/16 is when people starting finding springs on the new warranty replacement units.
Even the solid design has changed to a "not as solid" piece.
'13 ZL1
'06 TBSS
'98 TJ
'87 GN
Old 07-25-2018, 11:31 AM   #12
HDRDTD
It's my understanding, that the original spring loaded design was replaced with a solid coupler for a while, then they went back to a spring loaded design, but the second spring design was also packed with grease/lube.
Since the entire SC assembly is considered a field replaceable unit that is manufactured by Eaton, I doubt that there would be a GM TSB that would show/list the inner details of the coupler.
That info would probably have to come from Eaton, not GM.
Old 08-03-2018, 06:47 AM   #13
Bosse'sBoss
Bosse'sBoss's Avatar
Drives: '16 Camaro SS 6 spd manual transm.
The most important change is that the '14 & '15 had a revision improving their S.C. for the rest the only difference that you would see is the change on rear lights and rear diffuser design that's it.
'16 Camaro SS
Prior cars:
'14 Corvette C7 Stingray Z51
'14 Camaro ZL1 w/. Recaro seats
'11 Mustang GT 5.0 w. track package
'02 Porsche 911 Carrera
'05 Infiniti G35 coupe sport
Bosse'sBoss is offline   Reply With Quote
Old 08-03-2018, 11:33 AM   #14
VRZL113
VRZL113's Avatar
Drives: 2013 VR ZL1, M6
My blower was replaced right before I purchased my car in Nov 2017. I have the newest version with the updated spring coupler, and it has been problem free so far.
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
VRZL113 is offline   Reply With Quote
