03-12-2017, 11:38 PM | #1 |
Replacement Dealer Superchargers - Solid or Spring Isolator?
This came up in a separate fb thread. But curious amongst all the peeps here. Of those who have had the dealer replace the supercharger under warranty for the "marbe noise" isolator issue, how many have verifyably gotten a replacement supercharger that did NOT have a solid isolator and had a spring one like the previous supercharger they brought it in with?
When I had mine done they definitely put in a supercharger with a solid isolator, but I'm hearing from others that sometimes they have replaced it with the same type with the spring isolator still. Wanted to gauge how common this was and get any info. Seems dumb that GM would go to all this trouble replacing the SC just to put on one that could just potentially fail again. But then again I've seen stupider things from GM on my vehicles. Thanks.
2013 Camaro ZL1 M6: Rotofab CAI, JDP ZL-R Rough Idle Cam, Upgraded Valve Springs and Pushrods, Ron Davis Heat Exchanger, Alky Methanol Injection, Rx Catch Can, 87mm VMAX Ported TB, Summit Performance Spark Plug Wires, 10" Lower Pulley, Kooks 1 7/8" Headers with Magnaflow Cats, ID850 Injectors, Johnson 2110R lifters, EBC Slotted Rotors+Hawk Pads, Rotofab SC Coolant Reservoir, 160* Thermostat, Custom Mild to Wild switch, Tune, 1st to 4th bypass. 685 RWHP / 640 RWTQ.
03-12-2017, 11:57 PM | #2 |
"BEASTM*DE"
I think that they developed a newer version of the spring isolator that they are installing now, and are no longer using the older version...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
03-13-2017, 06:36 PM | #3 |
Drives: '12 SIM ZL1, 1 of 49 Join Date: Sep 2011
The tech who replaced mine said that they (GM) used up all old stock superchargers (spring drive) before switching over to the solid coupling. He told me to wait a while before having the replacement done. My SC was replaced in Feb. of 2014. It has a solid coupler.
03-13-2017, 07:23 PM | #4 | |
Wow that's ridiculous. Lets put another bad part in and wait for that to fail...
03-13-2017, 09:10 PM | #5 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
New Supercharger Noise TSB 15-06-01-003 #15-06-01-003: Supercharger Noise - (Nov 4, 2015) |
03-14-2017, 10:54 AM | #6 |
Drives: 2013-ZL1, 69-Z28, 71-CHEVELLE SS Join Date: Oct 2016
Here is updated tsb #15-06-01-003A: Supercharger Noise –(Dec 22, 2016) 2009-2015 Cadillac & Chevrolet
http://gm.oemdtc.com/5072
2017 C7 Z06
2013-ZL1 2017 HELLCAT SOLD 2019 HELLCAT REDEYE WB 69-Z28, LSA SWAP, T56 MAGNUM 71-CHEVELLE SS, 496 STROKER TH400 |
03-14-2017, 11:52 AM | #7 |
Drives: ZL1 Join Date: Jun 2015
So question for everybody on this thread. I ordered my ZL1 from the dealer in April of 2015 and took delivery in late June of 2015. Should i be concerned that I have the older parts on my SC ? Or do you think by then , they started to build them with the better parts at the factory ? Thanks in advance !!!
03-14-2017, 03:32 PM | #8 | |
KaBoom1701
Mods:
03-14-2017, 09:10 PM | #9 | |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Bryan 2018 ZL1 M6
03-15-2017, 06:18 AM | #10 |
2017 C7 Z06
03-15-2017, 11:51 AM | #11 |
1000hp is NEVER Enough!
Yep, Replaced with solid
Hello, Mine is a 2013, had the dreaded marble noise after 5000 miles. Supercharger was replaced under warranty before I tore the engine down. The replacement coupler was solid when I opened it up. Sorry, best picture I got of it, but it looks just like the LPE coupler. My supercharger is over driven 31%, I have had no problems and no noise in 6000 miles since the replacement. (found better pic of new GM / Eaton Coupler)
1,000hp IS NEVER ENOUGH!!!
03-15-2017, 12:52 PM | #12 |
Drives: 328xi, ML400, ZL1 man. 2013 Join Date: Aug 2012
resplaced my SC on 2013 zl1 due to marble like noises. had a solid coupler for 2 years and had it replaced again due to buzzing vibration noises. The snout was replaced with the revised spring loaded coupler and am very happy with it. The spring loaded coupler smooths out the engine, manual shifting feels great now and no more vibrations. hope this new coupler survives a long time. This engine works best with a spring loaded coupler.
03-15-2017, 05:11 PM | #13 | |
2017 C7 Z06
03-15-2017, 07:02 PM | #14 |
Gearhead
Drives: 2012 ZL1 Join Date: Jun 2014
I assure you that Eaton and GM used a sprung isolator for good reasons, and it wasn't just to force an expensive warranty campaign several years later. Now, I'm guessing that part of this was to provide NVH that was satisfactory for a Cadillac and that us Camaro owners may not be as picky (I can't hear much of anything over my exhaust), but this wasn't designed on accident.
I can also say that the isolator that was original used appears totally insufficient for transmitting ~50 HP from the input shaft to the rotor pack, and it's unclear to me how this part could have ever been deemed satisfactory after typical validation testing.
2012 Chevrolet Camaro ZL1 M6 - JRE 650 RWHP kit, AFCO heat exchanger, JPSS V4 aero, Z28 wheels for the twisties and Weld big-n-littles for the dragstrip. 11.193@128.13 in 515' DA |
