01-14-2014, 02:41 PM | #1 |
Drives: Camaro SS/RS 1LE (2014) Join Date: Nov 2013
Best brake line & brake pads package for track day
I bought a 2014 I LE camaro and I was looking to comply to track my car, I was told that I need to replace my brake lines and pads, including the brake fluid, Please any suggestion on what to buy as a good package, one that you guys have test already. thanks for the help (not sure is there is already a thread on this, I was searching and can't find anything)
01-14-2014, 02:52 PM | #2 |
So Cal Race Team
Drives: 2013 Camaro Join Date: Mar 2010
Tyler at JDP Motorsports can help you out...
01-14-2014, 03:33 PM | #3 | |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
I don't agree that you NEED to change pads or lines.....Brake fluid Yes, but many of us have tracked our cars with the stock pads and lines. Feel free to browse my links below in my signature about tracking the car stock. http://www.camaro5.com/forums/showthread.php?t=302569 Matt
01-14-2014, 05:00 PM | #4 |
Drives: 2019 Chevy Equinox Premier AWD Join Date: Mar 2011
I agree with Matt (who has instructed) and I track using the stock brakes. There is no need to replace your pads or brake lines UNLESS you feel that your car's stopping is not happening "quick" enough for your CURRENT driving style. Factor in also how agressive of late braking you plan to do and what types of courses you will run. I've had the stock brakes fade, but only a little and after a long fast straight and many laps of hard use. But they still worked great. Just get or do a fluid flush and replace it with high-temp racing brake fluid. But make sure it's dot4. Some people here swear by Motul 600. I've not used the stuff myself...
Also another simple but effective thing to do is get a "track" alignment done. Pedders has good recommendations on this: http://http://www.camaro5.com/forums...rack+alignment Mark
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43) |
01-14-2014, 05:04 PM | #5 |
Another thing is to follow what the manual recommends for Performance and Competitive driving. I think it recommends to replace the fluid in the differential before the competitive driving (I had it done the first time but not the second time.) Again depends on how agressive and how hard and long you will run.
(1 of 43) |
01-14-2014, 05:50 PM | #6 | |
So Cal Race Team
01-14-2014, 07:48 PM | #7 |
I agree for insurwnce but if you are a novice younshould be ale to get bynthe first time out to see how you ahndle the car stock and go from there.
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
01-14-2014, 09:00 PM | #8 | |
Can a brake hose or line play a factory in brake fade.....Yes, In extreme cases the line can flex more due to heat. But overall that is minimal at best. The primary reason for brake fade is heat generated by the friction between the pad and the rotor is transfered to the piston in the caliper which is in direct contact with the brake fluid. The moisture or water in the fluid can boil and create a spongy pedal or fade. I never tracked my car with stock fluid so I cannot speak about how it performed. I did run the car with stock lines and pads with Motul 600 fluid very hard on the track for 20 minute session without issue in Michigan. Bottom line: Fluid is a must! If you can afford lines and/or pads that is your call.... Matt
01-15-2014, 12:18 AM | #9 |
Drives: 2013 2SS/RS VR 1LE Join Date: Jan 2013
To the guys that have changed their brake fluid over. Do you run with the clutch and brake reservoirs separated or together?
Can the Motul 600 fluid go in the clutch lines too? Last edited by 1LeSS; 01-15-2014 at 09:50 PM. |
01-15-2014, 12:35 AM | #10 | |
Drives: 2014 2SS 1LE Join Date: Dec 2013
* * * * * * * * * * * * ** ************************************************** ***** * ** ************************************************** ********************** In "fact, the 1LE is SCCA certified for Touring Class Competition and was clocked to be faster than the existing T2 track record at the Pittsburgh Race International Complex.Best of all, this 1LE is here to stay." |
01-15-2014, 07:33 AM | #11 |
Thanks for all the answers, the reason for changing the brakes line are rules of the tracks here at PR, I just tell them that the car was certified but they said that if I want to track the car I need to upgrade the brakes lines and brake pad including the brake fluid.
01-15-2014, 10:18 AM | #12 | |
Ok Motul 600, Brembo 600 or ATE Super blue for fluid. I don't have different pads or lines so I will let others answer with their experience. Matt
01-15-2014, 10:21 AM | #13 | |
So Cal Race Team
01-15-2014, 06:48 PM | #14 |
That is a dumb rule. I understand the brake fluid but the pads? Every car is different so I understand if I have stock pads on a Civic I need to do something but the stock SS pads are fine on the track and besides that they will never know unless they also require you to install the pads at the track under the eye an inspector. Our stock pads are upgrades for other cars.
