Voodoo Medicine Man
Drives: Black 2SS with RS package Join Date: Jul 2010
Newer Camaro Rear Bowtie: No holes in the trunk?
I just replaced my bowties for some polished aluminum bowties. When I removed the rear one, much to my surprise, there were no holes in the trunk! The car was made 05/10 and its a 2010. Can anyone else confirm?
Might be useful if you are planing on going badgeless or buying a rear light up bowtie (no where to run wires) ![]()
Mine was built in may '10 I'll check mine see if it has holes
I dont have holes in mine either...Damn I wanted to get a light-up bowtie eventually.
K1NG CAM
I THINK MINE WAS BUILT IN 05/10 IM GONNA CHECK MINE
June '10
Drives: '10 2SS/RS RJT Join Date: Jul 2009
How do you tell if you have the holes? Is there a way of telling without removing the bowtie? My car was built on 5/13/10
#6 |
I will never know, I love my Bowtie.
#7 |
Voodoo Medicine Man
I took mine off, thats how I found out....there must be somewhere in the trunk where you should be able to see the posts because of the light up bowtie wires get routed through there...
#8 | |
June '10
. Not having holes underneath would be fantastic as I plan on doing something like this. |
#9 |
YDLYLB
Mine was built in April of 2010. I'll be checking this tomorrow.
#10 |
Mine was built in late april 10'. I opened up the lid and tore back the carpeting. I looked through the hole next to the truck latch and could not see any holes or bolts passing through. Not sure if that is the same metal or if it's double walled( I doubt it since you can see the spoiler bolts). Late april 10' is confirmed no bolt holes for the bowtie.
#11 |
June '10
I have them, build 5/15/10 :(
Here's how you tell if you have pins Tools you need Scraper Claw Hammer Trunk Lid What to do Note that the cover is angled down for when you go to replace it Slide scraper behind plastic cover between cover and trunk lid carpeting Pry towards yourself Do the same thing on this side (when popping this side make sure to hold the cover so it doesn't fly off) Pry towards yourself Plastic tabs on trunk latch cover Slide scraper behind plastic pin between pin and trunk lid carpeting Pry towards yourself Slide claw of hammer between plastic pin and carpeting Tap hammer end with hand so plastic pin slides between claw Pry towards yourself and pop the plastic pin out There are 11 pins in total Next you need to remove the emergency trunk release handle, pull carpeting out and towards yourself then up While pushing up on bottom of carpet pull down on emergency trunk release handle Flip handle over Tip handle down to remove metal pin from back of handle Place finger behind metal pin and push towards yourself Metal pin should pop out Pull carpeting up and towards yourself letting metal pin slid through the carpeting Bare trunk lid Left side Plastic pin :( Right side Plastic pin :(
#12 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Truck Join Date: Mar 2010
Nice......Very uh....Detailed directions!
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me! |
#13 |
June '10
Yeah, little overboard but it's better to have too much then not enough right
#14 |
Huh weird that yours has it
| Gran Turismo 5... No Camaro? | 5thGenOwner | 5th Gen Camaro SS LS LT General Discussions | 111 | 12-06-2011 11:06 AM |
| Major Pedders Event in Houston! Saturday, Jan 30th! Meet DMS | Info@PeddersUSA.com | USA - Texas | 39 | 02-01-2010 01:48 PM |
| Official Camaro Convertible CONCEPT Press Release | Tran | Camaro Convertible Forum | 12 | 11-18-2009 08:05 PM |
| The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 106 | 10-19-2009 07:08 PM |
