Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Vendor and Seller review / feedback / experiences
Old 08-14-2010, 01:23 AM   #1
SS Drifter
Drives: 2010 2SS/RS L99
Thumbs down AACstyle P13W LED
The quality control of P13W LED bulbs are extremely poor. They don't fit properly and many buyers buyers are have premature failure. AAC just keeps selling the same junk.
As much as you may want to believe that this will work, don't waste your money. This only incourages more scams like this one.
SS Drifter is offline   Reply With Quote
Old 08-14-2010, 01:30 AM   #2
xBlackout_Camaro
xBlackout_Camaro's Avatar
Drives: 2011 Camaro SS/RS Cyber Grey
I've loved every aac style light ive installed so far, which lights are you talking about
xBlackout_Camaro is offline   Reply With Quote
Old 08-14-2010, 02:41 PM   #3
fieldgoal00
Drives: 2010 Chevy Camaro 2SS/RS
I've had my P13W leds on my camaro for over 6 months now with no problems
fieldgoal00 is offline   Reply With Quote
Old 08-14-2010, 05:54 PM   #4
LS3 SS
Drives: 2010 Cyber Grey Camaro SS (LS3)
LS3 SS is offline   Reply With Quote
Old 08-14-2010, 11:28 PM   #5
SS Drifter
It sounds like you guys got lucky. My DRL LED replacements didn't fit and this seems to be a very common problem. AAC's solution is to modify the base with an xacto. BS in my opinion. I didn't pay $69 for a bulbs with bases that are out of spec... They are kind of pain to get to ya know. If they were advertised as great LEDs, no warranty and they might not fit I probably would have passed on buying them.
Quality problems happen but, you don't keep selling parts out of a bad lot. You fix the problem or discontinue the product. I have to wonder how many C5 members are stuck with DRL bulbs that don't fit right.
Old 08-14-2010, 11:35 PM   #6
AntzV
AntzV's Avatar
Drives: blacked out 2010 Camaro
I've also had many problems with there lights, I personally think they are very poor quality and over priced
AntzV is offline   Reply With Quote
Old 08-15-2010, 12:04 AM   #7
khislop007
ZEUSS
khislop007's Avatar
Drives: Hard!
Mine gave trouble too. I am on my second set now. I had nine LEDs out on one build and seven out on the other with two flickering.
I'm thinking of getting the non rs fog light housing and putting hids in them but not the kit from AAC
Old 08-15-2010, 12:03 PM   #8
RedJewel2SS
12.23s@113mph
RedJewel2SS's Avatar
Drives: 2SS/RS, A6, just a few bolt ons
i converted from the AAC leds to the BFXenon HID kit, and couldnt be happier with the choice! i got the 4300k kit to match the stock headlights. you can upgrade the stock headlights to 6000k or 8000k with matching fogs but that means more money!
RIP Cammie 7/15/2009 - 4/1/2011
RedJewel2SS is offline   Reply With Quote
Old 08-15-2010, 06:52 PM   #9
CAM-MARO
K1NG CAM
CAM-MARO's Avatar
Drives: 2010 Summit White LT
that sucks i was really thinking of buying those fog lights , i hope they can reslove these issues as to many people want these lights !
CAM-MARO is offline   Reply With Quote
Old 08-15-2010, 10:03 PM   #10
bossbunny
Mrs. Bunny to you
bossbunny's Avatar
Drives: Not a Camaro
I have all AAC lights and have had no problems.
bossbunny is offline   Reply With Quote
Old 08-16-2010, 08:52 PM   #11
CAM-MARO
K1NG CAM
CAM-MARO's Avatar
nice
Old 08-17-2010, 09:43 AM   #12
linkwpc
The punching cat
linkwpc's Avatar
Drives: '10 Camaro SS Black W/Hugger&W/IOI
I had my P13W from ACC and only lasted 2 days... Then it burnt out.... Plus its made my lamp housing was all brown. It look like it burn out with a little bit of fire but since there was not much air in there, it went out. But it could have burned up my car! P13W from ACC suck!
My car build (COTW 7/23/12) - - - - - - > CLICK HERE! : http://www.camaro5.com/forums/showthread.php?t=80725
linkwpc is offline   Reply With Quote
Old 08-17-2010, 02:02 PM   #13
Support@OracleLights.com
Support@OracleLights.com's Avatar
Drives: www.CamaroLighting.com
I know a lot of you are frustrated right now about the P13W bulbs not lasting as long as they should. We have been taking defective bulbs and testing them to see if there was any fault when we built the lights and nothing appears to be wrong with the bulbs themselves.
What we think is going on is the Pulse Width Modulated (PWM) Signal is sending fluctuating output voltage/currents to the P13W bulbs when they are set on "Auto" mode and because of this fluctuation the lifespan of the bulbs is being drastically shortened.
The P13W bulbs we sell for the DRL replacements for the RS equipped models are the same exact bulb we use for our 5202 LED replacement bulbs for the Non-RS equipped vehicles. The only difference in the back housing of the bulb that is different due to the difference in connectors for the two different models. We have seen a very small percentage of 5202 LED bulbs being returned, which further solidifies our assumption that the PWM signal that is being sent to the DRL bulbs from the factory harness is the leading factor to the problem customers are experiencing with the P13W bulbs.
In Non-RS equipped vehicles, since the Fog lights are actually Fog Lights, the circuit being fed to the replacement 5202 LED bulbs is actually a 12V non-modulated source which does not cause any interference with the operation of the 5202 LED bulbs.
We are working on a solution for you because we do not want any of you to be frustrated with our products. Right now we have an Advanced MECP and an electrical engineer working with us to get the problem rectified.
Support@OracleLights.com is offline   Reply With Quote
Old 08-17-2010, 02:27 PM   #14
RedJewel2SS
12.23s@113mph
do you believe this is going to shorten the lifespan of the stock halos or sidemarkers also? i am using your wiring harness that you provide with the DRL bulbs.
AAC LED bowtie and LED interior lighting Kwarren Cosmetics and Lighting Modification Discussions 8 06-18-2013 11:31 AM
AACstyle LED strip vs. CCFL footwell lighting binlow84 Cosmetics and Lighting Modification Discussions 29 11-06-2011 12:50 AM
100% Waterproof LED Strips with 12pcs of 5-5050 SMD LEDs starting at $12.95 each! Xenith Xenons Interior Parts & Accessories 54 01-23-2011 07:00 PM
