![]() Drives: 2SS/RS Join Date: Dec 2009
When to change differential oil ?
When should I change my differential oil?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS, 2018 Colorado Join Date: Nov 2009
![]() Drives: SummitWhite 2010 Camaro 2LT/RS 6Spd Join Date: Apr 2010
I was told every 30,000 but I got it changed after 6 months to make all of the metal shavings were gone from the original fluid.
I changed mine about 1500 miles. Lots of junk in the oil. Do not wait especially if you have an SS
![]() Drives: 2010 2SS Join Date: Jan 2010
I changed it Royal Purple two weeks after I picked up the car. I was getting antzy, it was stuck in the garage due snow for 2 weeks (plows don't pass in Richmond). So I changed all fluids, installed the skip-shift, Hurst Shifter, shift eliminator and went over inch of the car. FUUUN
Installed options;Tinted Windows, De-badged, Hurst Shifter,CAI,Vmax throttle body, Kooks LT Headers, High Flow Cats,Borla Touring Axle Back, ADM Scoop, Washwater relocation,Diablo Predator(c/w Ted's Magic), Custom start defeat switch, painted engine cover, shark fin & bow ties, ABL lighting, Rear Camera. |
#6 |
Never changed diff. fluid in any car I've ever owned.....never had a problem.
#7 |
#8 |
Camaro SS Lover
Drives: 2010 Camaro 2SS/RS Black IOM Join Date: Jun 2010
What's a shift up eliminator?
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
#9 |
Keeps you in low gear - works sorta like a speed limiter - good when you have teen-age drivers
#10 |
You must really hate shifting...
| 2010 Camaro V6 Oil and Oil Filter Change | azamazonqueen | Camaro DIY & HOW-TO instructions & discussions | 116 | 03-19-2017 02:36 PM |
| Oil Capacity LS3 | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 77 | 04-21-2014 11:19 PM |
| best synthetic oil to use | hollywoodjose | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 130 | 01-26-2014 09:51 AM |
| Car "waking up" after oil change..is this due to the fuse pull? | CamaroFemme | 5th Gen Camaro SS LS LT General Discussions | 6 | 10-05-2009 04:44 PM |
| Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 10:47 AM |
