Old 08-21-2010, 03:20 PM   #1
mcarney
mcarney's Avatar
Drives: SSRS CGM LS3
Low Gears, High Rev = High Pitched Screeching noise
I just noticed that when I take off hard in first gear I hear a high pitched screeching noise, its like a turbo screech.... I don't know exactly what RPM it happens at but I'll try and replicate the issue later this weekend. Its between 5 and 6.
I have no idea what this could be, can you guys help out?
Thanks
When you're really good in a past life, you come back as yourself
mcarney is offline   Reply With Quote
Old 08-21-2010, 03:33 PM   #2
shroomjohn
shroomjohn's Avatar
Drives: Golden Eagle
If it's a metallic sound u need to hit up the dealership
Loving this car!
shroomjohn is offline   Reply With Quote
Old 09-12-2010, 04:46 PM   #3
mcarney
mcarney's Avatar
Turned out to be the alternator.
Fuse Pull: Low Octane Fuel Fix For L99 and LS3. Reset Fuel Map for High Octane Fuel. radz28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2838 05-11-2024 11:42 PM
2010 Camaro PCM Pin-out Description and Wire Colors (LS3 & L99) raptor Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 14 06-02-2020 12:51 PM
Intermittent clicking noise at low speeds I8A4RE Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 11 01-07-2015 04:30 PM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 03:42 PM
Tranny "Knocking" noise at low RPM Haloman1346 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 09-01-2009 07:23 PM
