Old 08-22-2010, 01:28 AM   #1
Toasty
Custom User Title :D
Toasty's Avatar
Drives: 2011 Summit White 2LT/RS
Part number needed
Guys, a little help, please-
Can somebody with access to the wiring schematics for the Camaro look up and see what the part number is for the connector that plugs into the traction control switch?
(also need the pinout list, too)
Thanks!!!
Toasty is offline   Reply With Quote
Old 08-22-2010, 10:15 AM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
By the book its a 10 pin connector 2 row's of 5, OEM part number 15491259 it has a service number of 15127042, Description 10-way F YESC Kaizen Series (BK)
If your looking at the connector pin #1 is top right and the top ends at pin #5, The bottom row starts at the right side and is pin #6 to the lift is pin #10.
Call out is pin #1wire (.35 YE) LED Backlight Dimming control
Pin #2 (.35 BK) Ground
Pin #3-6 Not used
Pin #7 ( .35 L-BL ) Traction Control Switch Signal
Pin #8-10 not used
Let me know if you need more.
Old 08-22-2010, 10:25 AM   #3
showstopper
Drives: 2010 RS/SS
Sounds like somebody has a cool mod up their sleeve.
showstopper is offline   Reply With Quote
Old 08-22-2010, 06:56 PM   #4
Toasty
Toasty's Avatar
Eh, just a cleaner way to do a current cool mod
2SSRS-
do you happen to have access to a schematic/diagram of the LED/backlight dimming control?
Old 08-22-2010, 07:19 PM   #5
2SSRS@Gen5diy
Do you mean the ABL? And i have all the GM schematic/diagram for the car But i dont have a scanner at home, Only at work.
Old 08-22-2010, 07:36 PM   #6
Toasty
Toasty's Avatar
The ABL may be on the same circuit, but I was referring to the circuit that is in pin position 1 on the traction control connector. What I was curious to see wa if there was a splice pack/junction connector in the LED Dimming control circuit (splice pack/junction connectors are common in other GM vehicles for circuits that are branched out to alot of different points throughout the dash/car.
If I can't find what I want based off of the traction control connector, I'll need the pinout/part numbers for the jumper harness connectors that are used to hook in the 4 gage pack.
Old 08-23-2010, 04:24 PM   #7
Toasty
Toasty's Avatar
Hey man, I need p/n info for X7 BCM connector- is there a regular number and a service number? Dealer gave me number 19151265 but I can't find any info on it
Tail light bezel Part number? T_MECO Cosmetics and Lighting Modification Discussions 3 05-31-2010 08:49 PM
Scrming's Air Intake Experiment - Part II scrming Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 94 05-02-2010 04:56 AM
RS headlight headlamp part number? Jakefeb3 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 1 11-29-2009 01:41 AM
any body have the part number... ThunderSS Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 0 10-04-2009 11:16 AM
Backup sensors - part number? tcd Camaro Price | Ordering | Tracking | Dealers Discussions 4 09-22-2009 09:18 PM
