Old 08-22-2010, 12:47 PM   #1
Berean
Drives: Truck
Pfadt end links popping?
Ok, here's the set up:
I had Pfadt end links and sway bars installed by the local Chevy dealer about 800 miles (2 months) ago.
Last week when I drove the car, I noticed a "pop" sound every now and then which sounded like it came from the right rear. It got worse as I drove the car for a couple of hours, and by the time I got it home, the "pop" was a fairly constant "popping" sound.
I checked the rear sway bar to see if the bolts were loose which was an issue noted in another thread. All the sway bar and end link bolts appear to be tight.
Below are pics of the end links. They were NOT articulated at this much of an angle right after install. I know for certain, because I checked to make sure they were installed correctly and compared the install with the Pfadt install picture.
So, I think the popping sound is from the end links binding due to being over articulated. However, I'm no expert at suspension components, so I'd like some opinions, especially Pfadt's opinion of course.
If the end links are over articulated, and need to be readjusted, what would have caused that after 800 miles since all the bolts appear to be tight?
If they do need readjusted, I may try it myself. Is it as simple as unbolting them and reinstalling, or is there a specific way these need to be installed, i.e. on a lift etc?
Any help is appreciated. Thanks.
Berean is offline   Reply With Quote
Old 08-22-2010, 02:28 PM   #2
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
I had the issue of many of the bolts on the Pfadt components coming loose. Even after everything was tightened, I still have lots of suspension noise going over bumps...
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 08-22-2010, 02:41 PM   #3
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I think that angling you see is not uncommon. Mine are still the OEM links, but are not far off the angle you have there.
I'd look more to see if the problem lies elsewhere.
What do the other ends look like?
Old 08-22-2010, 03:07 PM   #4
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
I have the same end links with LSR sway bars... no problems. Have you checked the sway bar bushing mount bolts?
Cam 427 is offline   Reply With Quote
Old 08-22-2010, 03:11 PM   #5
CamaroSS8491
Drives: 2010 SS/RS LS-3
Ive had the same issue after a couple days of driving. I too am getting it on the passenger rear side. I ended up calling Pfadt to see if this was normal and basically what I was told is the bolts needed to be retightend. Because the bolts are so close to the frame its hard to get a torque wrench in there to get the required 45 lbs of torgue. So I will be hopefully taking the car back tomorrow to have them retighten all the bolts on the rear sway bar.
CamaroSS8491 is offline   Reply With Quote
Old 08-22-2010, 04:35 PM   #6
TCao
Drives: 2010 2SS RS, 2007 FJC
One of the potential causes of the popping noises could be the spherical bearing housings hitting the head of the socket head bolts. The quick fix is to reach around the rear wheels and turn the body of the endlinks so they look like the pic below. The rear wheels only move up and down in one plane (more or less, unlike the front wheels which also turn) so the endlinks orientation should not change. The other potential cause would be loose fasteners. The provided nuts are nylock type so they may not be properly tightened if the prevailing torque (to overcome the additional friction from the nylon locking element to turn them) are not taken into account. HTH.
TCao is offline   Reply With Quote
Old 08-22-2010, 05:07 PM   #7
Rob@WretchedMS
Drives: His Wife Crazy
Be 100% sure the bolts are tight, give them a little extra to be sure. especially the right upper
Be 100% sure the lock nuts are tight, if any one of those are loose it can make noise.
Rob@WretchedMS is offline   Reply With Quote
Old 08-22-2010, 07:38 PM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Do you have any other suspension mods?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 08-23-2010, 11:29 AM   #9
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Hi Berean,
There is a couple things here. First, the rate on our bars are high, and as a result, they require adequate torque. We have diagnosed noise complaints down to endlinks and chassis brackets being tight, but not to spec. The chassis brackets will not all be able to be torqued with a wrench, we understand that. But it is imperative that this be done to the best of your ability.
Second, The endlink hardware on the other hand, CAN be torqued with a wrench, and we have found this to be the source of most "noise" issues. It is because of this, that we are now requiring installers to torque these fasteners to 33 lb-ft. This will be enough torque to overcome any potential slipping as before, but will give more overhead to not everyone's torque wrenches being the same.
Do us a flavor and make sure this is done to spec, on the endlinks, and then also tighten down the chassis fasteners.
Please do not hesitate to give us a call, and if there is still noise after you do what was mentioned above, there is something else.
Old 08-23-2010, 06:12 PM   #10
CamaroSS8491
Just an update I took mine back to the guys that installed my suspension they re-tightened the end links each one turned about 1/4 turn. End result is that the noise is gone and its driving great.....
Old 08-23-2010, 06:16 PM   #11
JProberts
Drives: 2SS RJT RS/Sunroof
Great to hear
JProberts is offline   Reply With Quote
Old 08-23-2010, 06:23 PM   #12
Dr Jkel
Roll Tide
Drives: 2010 2SS RJT/BLK 6Spd Man
good to know it was more of an install than a product problem
MUSTANG...Like Bringing a Hot Dog to a Steak Dinner....There is no comparison.
Dr Jkel is offline   Reply With Quote
Old 09-03-2010, 12:58 PM   #13
Berean
Drives: Truck
Right rear end link nut was a little loose. Tightened up, and no more popping.
For Sale: Stock SS Springs, sway bars, end links Darth_Emma Suspension / Chassis / Brakes 5 07-12-2010 03:11 PM
PFADT Sways Fishdadddy Suspension / Brakes / Chassis 4 04-27-2010 07:33 PM
Do you need an alignment for just anti-sway bars and end links? Berean Suspension / Brakes / Chassis 5 04-15-2010 01:05 PM
2010 CAMARO HEAVY DUTY END LINKS Hotchkis Suspension / Chassis / Brakes 0 04-14-2010 05:47 PM
Pfadt Springs and Sway Bars In Stock! *Package Deal*! PfadtRacing Suspension / Chassis / Brakes 0 10-14-2009 05:41 PM
