Old 08-22-2010, 03:17 PM   #1
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
Question Cam install and spark plug help needed!
Well I'm installing my cam kit at home and came across a couple of problems.
First off does anyone know what the bolt specs are for the 3-bolt cam gear I bought the gear at the local dealer but he did not have the GM bolts in stock and said nobody in the Houston area had any either What he gave me and said would work are some generic 8.8 hex head bolts about an inch long each. To me they look too short and the heads of the bolts dont have flange or built in washer to seat on. They're just standard type bolts. Does anybody know if I can use generic hardened bolts or do I need washers or loctite and what length should they be? Also, when I pulled my spark plugs out, the ceramic and the ground electrode are a deep red color, almost like a rust red WTF?? I cant remember ever pulling spark plugs out of any kind of car and looking like that. And I've done hundreds of them... So do I reuse them, replace with new ones or go with the ngk's? Should I replace the T-stat to 160? I've read on here that the stock t-stat on the LS3's is better for performance.
Anyway if you guys can give me some insight on any of these things I would appreciate it very much.
Right now my car has Kooks headers w/high flow cats, Rotofab intake, muffler delete and stock tune.
Thanks, jrrod.
TEAM LS3 Best pass: 9.61 @ 146 with M6
TBDRWHP TBDRWTQ ECS S/C 408, YSi, m6, Mantic Triple, ZL1 diff
#BuiltByJRod.... J-Rod's Speed Shop.... Tuned by: Matt Sorian @ MS Tuning
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 08-22-2010, 06:36 PM   #2
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
Regular bolts on the cam, the highest grade you can find (12.9 pref). I used red loctite on mine, but some like thread sealant. The important thing is that they are torqued/stretched to spec and wont back out.
160 and 185 (stock) thermostats will make little/no difference. The car runs at 195-210, which is beyond both thermo's threshold.
Ovenmitt is offline   Reply With Quote
Old 08-22-2010, 08:15 PM   #3
4xchamp
MURC 666
4xchamp's Avatar
Drives: 69 Pace Car 68 Camaro Restomod 81 Z
Octane booster colors the plugs rust red .
Guys hoarding their Camaros are depriving some youngster the opportunity to restore it 25 years from now .
Drive it like you stole it , let the next guy baby it !
4xchamp is offline   Reply With Quote
Old 08-22-2010, 09:32 PM   #4
3min3m2
3min3m2's Avatar
Drives: 2011 2SS/RS SIM L-99
And I've heard fuel cleaner, water remover, etc do it too
3rd Time is the charm
2012 2SS/RS VR 6M.
Borla S type, Volant CAI.
3min3m2 is offline   Reply With Quote
Old 08-22-2010, 09:44 PM   #5
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Octane booster?? Who, me?? Neverrrrrr
Old 08-22-2010, 09:46 PM   #6
SSteve
Drives: 2SS/RS
Thanks, jrrod.
I would not recommend using bolts that are not the same length as the stock ones. However, a heat treated/hardened 8.8 bolt should be fine. Be sure to use red loctite.
I'd replace the spark plugs.
SSteve is offline   Reply With Quote
Old 08-22-2010, 09:47 PM   #7
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
What lengths do the bolts need to be?? Corvette torque specs??
Thanks everybody for the help
Old 08-22-2010, 09:56 PM   #8
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
I'm converting to 3-bolt from 1-bolt so I dont know how long the stock ones are on a 3-bolt set-up. I wanted to keep 1-bolt but the cam I got was only available in 3-bolt.
Old 08-22-2010, 10:55 PM   #9
Slowhawk
Drives: 1999 Trans Am
To me 3 bolt gears are stronger.The bolts are about 1" long. I'd prefer the correct GM one's (but we have a ton of spare gm bolts from jobs) but a 8.8 should be fine.Use red loctite and I think the torque is 28 ft/lbs. (I torque them to stretch,never had 1 back out in 10 years)
The red plugs are additive in the gas.
Slowhawk is offline   Reply With Quote
DIY : Install headers on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 70 06-25-2020 07:40 PM
New spark plugs for maggie install? JB @ C and L Machine Forced Induction - V8 12 08-24-2010 08:45 AM
Spark Plugs Strokedhog Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 01-06-2010 12:35 PM
Nitrous oxide and Challengers Superman09 General Automotive + Other Cars Discussion 16 01-29-2009 09:14 PM
