![]() Drives: 2010 Black 2SS/RS Join Date: Jan 2010
After the S/C install...
Currently my plan is to install a maggie S/C then later down the road upgrade to LT's and 3" exhaust.
How difficult is it to reprogram after S/C install |
I'm not totally useless..
The canned tune won't handle any mods beyond the SC itself. You will need to have it dyno tuned or obtain a custom tune from Jannetty Racing or similar (you will need to datalog for it) after the upgrades.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS w/ ZZ427 Package!! Join Date: Oct 2008
Exactly... for the start you will be in good shape using the tune that comes with teh supercharger...
When you go to headers or upgrade the intake etc... You will need to hit up a dyno tune.. That will make more power and will be worth every penny!! |
Psssssssssshhhhhhhhhhhhh!
Drives: under contruction Join Date: Nov 2009
When you put the headers on, you will want to change the pulley to keep your boost up. I went with the 3.6" pulley with my car (which has LT headers). The standard maggie kit comes with the 3.8" pulley.
I'd suggest you think about doing headers first then add the maggie after so you don't have to swap pulleys. |
![]() ![]() Drives: 2010 Camaro 1SS/RS RJT Join Date: Jan 2010
Whats the usual HP increase between the canned tune and a dyno tune with a S/C?? Maggie, Vortech..any really.
2010 Camaro SS LS3 Holley Hi-Ram Manifold,Custom grind boost cam,Vortech V-3,10Rib 3.47 Pully Airfilter Pipe Delete, 10 PSI, TSP LT Headers, Flowmaster Outlaws, Alky Control Meth Kit, PFADT 1.25, ZL1 Fuel Pump, DSS 1000HP axles, Mantic ER2 Clutch, Full BMR rear suspension drag pack upgrade. C6 Vette 18 rims with M/T 305 out back. COPO Hood
Race Proven Motorsports tuned |
#6 | |
![]() ![]() Drives: Silver SS/RS, Man 6 Join Date: Apr 2009
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers, GM 3.91 Rear Gears |
| INSTALL OF BARTON SHORT THROW SHIFTER | BLACK10 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 141 | 03-20-2017 11:01 PM |
| DIY Hurst Short Throw Shifter Install - Pix and Video | TAG UR IT | Camaro DIY & HOW-TO instructions & discussions | 121 | 02-26-2015 11:08 AM |
| Black powder coated Phantom grille + LED halo headlights and foglights install | klove | Cosmetics and Lighting Modification Discussions | 88 | 04-19-2010 03:52 PM |
| DIY : Install catback on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 3 | 08-09-2009 05:36 PM |
