08-24-2010, 02:45 PM | #1 |
Drives: 2010 SS Black Join Date: Jul 2009
New Dyno Numbers - 638 RWHP - 624 RWTQ ( what the HP at the block )
2010 camaro LS3 motor-Ran a test on a new mustang DYNO today. car hit 638 rwhp and 624 rwtq. many people have made comments that the mustang numbers are more true but are about 8 to 12 percent below and dynojet, in addition the flywheel horsepower would be even 12 to 15 percent more. At my present numbers at the rear wheel would this mean my motor is pushing 775HP at the flywheel, does this sound right???
08-24-2010, 03:10 PM | #2 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Using a 15% loss, it would be closer to 750 ...
08-24-2010, 03:13 PM | #3 | |
www.jannettyracing.com
08-24-2010, 03:41 PM | #4 |
Drives: 2014 Corvette M7 Join Date: Aug 2010
Easy way to figure your wheel hp to engine hp is to divide by .85... or .8 for an auto.
08-24-2010, 03:58 PM | #5 |
Drives: RSSS Join Date: Dec 2009
08-24-2010, 04:05 PM | #6 | |
Okie doke
ex. 650 / .85 = 764.7 650 * 1.15 = 747.5 I think the / .85 way is correct .. Crowley
08-24-2010, 04:07 PM | #7 |
maggie with 10 lbs bost
stage 2 cam CAI kooks 3' full headers to tip meth injection 160deg ther question is if you all think 750 would be a valid number using a mustang what do you think i would get using a dynojet? |
08-24-2010, 04:08 PM | #8 |
Drives: red jewel camaro Join Date: Aug 2009
Multypling by 1.15 is more reasonable.
If a typical stock ls3 is 370...multiply that by 1.15 and you get 425.5
2010 Red Jewel Camaro ss/rs
A6/L99 POWER NUMBERS....874 rwhp/880 rwtq!! 9.81@142.02 Livernois 2nd Place Car Camaro5 Fest Original Build 13 psi/nittos.....10.44@134 3.6KB/3.5 pulley/Stock t/b..Best 9.967@142.01 SSJ3...is done....mid 9s?Rossler 6l80E Transmission KB 3.6LC,17" Bogarts, Thanks to Hendrix 9", Thanks to Pfadt original T/b and converter, 419ci stroker (NO LSX Block) |
08-24-2010, 04:12 PM | #9 | |
So the formula would be: x(1-y) = z x = flywheel y = % (15 for manual and 20 for auto) z = rwhp going from rwhp to flywheel would be: z/(1-y) = x |
08-24-2010, 04:15 PM | #10 | |
Okie doke
it depends on how the dyno was set up ... Just say the mustang dyno reads say 3 % lower than a dynojet .. 638 / .82 = 778 On a dynojet it could read 661 rwhp (778 / .85) Again .. all depends on how the dynos are setup etc .. use the dyno as more of a tool for mods and see differences ... Crowley
08-24-2010, 04:16 PM | #11 |
manual,
i guess the real question is if im getting 638 on a mustang what would i get on a dynojet and then what would be my end horsepower |
08-24-2010, 04:18 PM | #12 |
reason being is that the orignal horsepower rating from chevy was posted on a dynojet, using the same type of gauge would be what i would compare with...
08-24-2010, 04:38 PM | #13 | |
Okie doke
Crowley
08-24-2010, 07:20 PM | #14 | |
Similar Threads | ||||
Texas Speed Long Tubes & Rumbler 5 Cat-Back Dyno Results! | Trevor @ Texas Speed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 48 | 12-08-2018 02:37 AM |
Camaro SS 2010 on dyno makes 364 whp & 371 rwtq !! Vid inside | UCF w00t | Camaro Photos | Spyshots | Video | Media Gallery | 128 | 03-20-2011 10:27 PM |
V6 Camaro Dyno numbers are in!! | MadMaxx | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 145 | 10-07-2009 06:38 PM |
Another set of dyno numbers plus.. | scrming | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 25 | 07-10-2009 04:47 AM |
Dyno numbers for axle-backs? | LDGn63 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 12 | 07-08-2009 06:20 PM |
