Old 08-25-2010, 04:12 PM   #1
tylermoore
Drives: 2010 Camaro 1ss/LS3 Victory Red
Angry Need Help My LS1 Has No Oil Pressure
I have been letting my mother drive my ls1 a4 back and forth to work for awhile now and she told me the other day the car lost its power like the drop of a hat. I figured it was just not run enough and maybe it needed some plugs since she said it was bucking. Then she tells me that it wont go past 45mph. So i finally get a chance to see what is wrong with it and i found that when driving the car is running seroiusly about 5psi oil pressure. It keeps cutting off and has plenty of oil in the motor. The oil was changed in may and has been driven about 600miles since then. The motor has about 128XXX on it and is all stock.
I dont know what to do besides not drive it.
Please send me some ideas on what to do i am lost. i have new plugs ready to put in because the motor is bucking but im thinking it is because of the loss in pressure.
2010 Camaro SS/LS3
1998 Camaro Z28 A4
tylermoore is offline   Reply With Quote
Old 08-26-2010, 06:57 AM   #2
BlackieRay
Drives: 2002 WS6
Is there any knocking? When it is running, does the oil pressure gauge move back and forth? Do not drive the car anymore. Have it towed to garage that does engine rebuilds. It sounds like you have spun the bearings somehow. The mechanic should be able to tell you why, but spun bearings can be caused by overheating.
BlackieRay is offline   Reply With Quote
Old 08-27-2010, 11:20 AM   #3
Raven02TA
Raven02TA's Avatar
Drives: 2002 Pontiac Transam. 2004 Tahoe,
Send a message via AIM to Raven02TA
if the motor isnt making any noise leave it as it is do not keep running it. it sounds like the oil pump decided to let go and/or the o-ring from the pick up tube to the pump went bad and is venting pressure (this is he more likely scenario) this is a fix/repair you can do yourself or have have a mechanic check.fix.
have you drained the oil and looked for excess metal on the plug/in the oil?
Raven 2002 Trans Am, 585rwhp/578rwtq
Raven02TA is offline   Reply With Quote
Old 08-27-2010, 09:12 PM   #4
tylermoore
when i first crank up the car it will run normal oil pressure with a slightly choppy idle no motor knocking or bearing noise. The cats decided they were gonna bust on this day also and i think they are broken up inside the pipes and cant get out. Which explains the loss of power but it doesnt explain the gauge reading no oil pressure. My mom drives the car super easy and i havent driven it in about 3 months
2010 Camaro SS/LS3
1998 Camaro Z28 A4
Old 08-27-2010, 09:14 PM   #5
tylermoore
The oil pressure when cranked seems fine but after it warms up it runs inbetween 0-20 then it just stays on 0 and the dash says check gauges...
2010 Camaro SS/LS3
1998 Camaro Z28 A4
Old 08-27-2010, 11:09 PM   #6
lil_red_v6
one wheelin
lil_red_v6's Avatar
Drives: 2004 yamaha r6
Send a message via Yahoo to lil_red_v6
roll over to ls1lt1.com
lil_red_v6 is offline   Reply With Quote
Old 08-27-2010, 11:40 PM   #7
Raven02TA
Raven02TA's Avatar
oil pump or oil pump O ring. and/or your oil pressure switch is bad. if the motor isnt making noise it in itself is more than likely ok. swap the oil pressure sensor (which is around 20 bucks) and then start the car and see if that fixes it. if not than more than likely its the pump or the oil pump O-ring which is NOTORIOUS for failing on LS based engines.
Old 08-29-2010, 07:48 PM   #8
tylermoore
k thanks will try it
2010 Camaro SS/LS3
1998 Camaro Z28 A4
Old 09-14-2010, 01:15 AM   #9
Raven02TA
Raven02TA's Avatar
update?
Old 09-14-2010, 10:19 AM   #10
ImportImage
ImportImage's Avatar
Drives: 2012 GTR, 2009 GTR
Send a message via AIM to ImportImage
yup what he said- if you get a new pump get a ported oil pump as well. Also the 98 are on the only 4gen that the guages are actually correct, so I would not drive it till you have found the problem.
ImportImage is offline   Reply With Quote
Old 09-14-2010, 10:27 AM   #11
usmc8411
Drives: 2010 camaro
If a woman was driving it when the problem occured...your motor is toast. They dont notice things till its too late. It was probably run for a while without oil pressure. Im Just saying. I would hope for the best, but expect the worst.
usmc8411 is offline   Reply With Quote
Old 10-13-2010, 04:58 PM   #12
CamaroMeltdown
Drives: Silverado LS1(for now)
Sounds like the distributors and distributor shaft
CamaroMeltdown is offline   Reply With Quote
Old 10-13-2010, 06:32 PM   #13
SC2150
GenII & GenIV engines have no distributor and the oil pump is driven from the front of the crankshaft, not like the old school motors that the can gear drove both the distributor & the oil pump.
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 06:11 PM
Can we use the catchcan made for the G8? HaZe_X Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-05-2010 10:35 AM
now logging actual line pressure in A6, less than 100psi in 3rd parish8 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 02-20-2010 09:46 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 10:40 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
