Old 08-26-2010, 02:10 PM   #1
Jeffro
Jeffro's Avatar
Drives: 2010 Camaro 2SS 6M
BMR vs Hotchkis chassis brace
Im looking for something to stiffen the chassis and make it handle a little better. Subframe connectors along with the tunnel brace offered by BMR mounts in a different position than the hotchkis brace. They mount differently but both claim the same results of strengthening the chassis and improve handling. Does anybody have either to help me decide??
Halltech cold air intake
ARH long tube headers 1 7/8
3" exhaust no cats
Borla S type mufflers
Diablosport tune
Jeffro is offline   Reply With Quote
Old 08-26-2010, 02:42 PM   #2
dmax86
dmax86's Avatar
Drives: 2016 Z06 C7R
i like my hotchkis. it has a different appeal even if the do the same thing and its color blends in well. the hotckis connects further towards the rear connecting the subframe at a different point... check them out
2013 ZL1 BONE STOCK! LOL
dmax86 is offline   Reply With Quote
Old 08-27-2010, 10:04 AM   #3
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Both are similar looking, but surprisingly different. Hotchkis chose to minimize rear cradle movement with their chassis brace, BMR chose to minimize rear cradle movement with better quality bushings and leave the chassis stiffening to our subframe connectors. Our chassis braces tie 3 main structural points together - the front subframe, the driveshaft tunnel carrier bearing mount, and the rear subframe.
This effectively creates a triangulating web, structurally tying all 3 points together. Hotchkis ties 2 frame points together and the third point is the rear cradle. We feel that bushings are a better solution to minimizing the rear cradle movement then by tying a rigid brace to a moving cradle. Two opinions, two different products.
BMR guy is offline   Reply With Quote
Old 08-30-2010, 01:17 AM   #4
Silver2SSRS6spd
Prefer to be blown!
Silver2SSRS6spd's Avatar
Drives: 2010 Silver/Black 2SS/RS Manual
Is there a BMR coupon code anywhere? I want to purchase the subframe connector and the driveshaft loop.
MagnaCharger TVS-2300 550rwhp 540 rwt and a radical suspension under the car.
Silver2SSRS6spd is offline   Reply With Quote
Old 09-01-2010, 06:59 PM   #5
Hotchkis
Drives: 1st through 5th gen Camaros
As BMR says, different solutions, both result in superior ride quality over stock.
We wanted to make our 2010 Camaro components as simple and effective as possible. The Hotchkis Chassis Brace reduces chassis flex and improves traction during hard launches and high-speed cornering by triangulating the rear sub frame to the chassis frame rails.
We wanted to make it an easy bolt on with no need for other components to make it work. We also designed it to have the best possible ground and exhaust clearance.
Hotchkis is offline   Reply With Quote
Old 09-01-2010, 07:28 PM   #6
nl12
Drives: Unicycle
Maybe a dumb question, but can you install both or would they conflict?
nl12 is offline   Reply With Quote
Old 09-01-2010, 07:39 PM   #7
Hotchkis
While your spirit of teamwork is refreshing, you'd have some clearance issues with both braces.
Old 09-05-2010, 03:50 AM   #8
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
hotchkis is a superior product for all around use, easy to install, great exhaust clearance amd ground clearance. felt a big difference as soon as i installed it and its lightweight.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 09-05-2010, 07:57 AM   #9
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Not putting down either of the units but if you're wanting better handling, there are better places to start. Better sways and bushings would be a better place to start and will give you a more noticeable improvement in handling. After you've done those, and you still feel you need more, then move on to subframe connectors. It just seems like you're skipping a obvious step in the upgrade path.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-05-2010, 08:54 AM   #10
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Both the BMR and Hotchkis braces are great products that will result in an improvement over stock. However, if you are just beginning to look into suspension mods then I agree with Axis. I would start with sway bars and springs and then start looking into bushings and braces.
Old 09-05-2010, 09:26 AM   #11
Silver2SSRS6spd
Prefer to be blown!
I did the sways and trailing arms first, now doing the SF connectors. Waiting on the springs till I get mire info since I have read hear that they might be an issue with the rear end breakage problems.
Old 09-05-2010, 05:42 PM   #12
axis
Search Ninja
axis's Avatar
Chase and I were referring to the OP.
What rearend issues are you referring to? I've heard they may shorten the life of the shocks but haven't heard anything about rearend breaking issues.
Halltech CF 102 fed
Old 09-07-2010, 12:06 AM   #13
Silver2SSRS6spd
Prefer to be blown!
I read somewhere that the axles seem to be snapping on a lot of the cars that have been lowered. Not sure if this is true or not so I'm holding off until I have more facts.
Old 09-07-2010, 02:29 AM   #14
axis
Search Ninja
axis's Avatar
That's not a lowering issue but a power issue. I would say that 99% of snapped axles were on cars that are FI'd or cammed with stickier tires or at a race prepped track. I think it's just coincidence that most people that have greatly increased the HP in their cars have already done several suspension mods. That includes upgraded sways, trailing arms, and poly bushings. To my knowledge, lowering springs don't affect the axles in a way that would make them susceptible to breaking. It's more a aero/balance affect. Poly bushings would cause more possible harm to axles than springs.
Halltech CF 102 fed
Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H AJ@ECSMotorsports Suspension / Chassis / Brakes 80 11-17-2010 03:28 PM
Hotchkis 4-Point Chassis Max Front Strut Brace AJ@ECSMotorsports Suspension / Chassis / Brakes 57 11-13-2010 04:29 PM
Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! Circuit Motorsports Suspension / Chassis / Brakes 99 05-24-2010 05:21 PM
LMPerformance, Hotchkis 2010 Camaro Chassis Max Brace LMPerformance V8 Bolt-Ons & Tunes 0 01-05-2010 12:17 PM
BMR CHASSIS BRACE INSTALLED lawdogg149 Suspension / Brakes / Chassis 19 12-14-2009 09:39 AM
