Old 08-26-2010, 08:43 PM   #1
ducq
ducq's Avatar
Drives: 2010 Camaro 1SS/RS LS3 blck w/ IOM
Changing the clutch fluid
Is it difficult to do it yourself? I've got 8k miles on my car, I'm putting Ina short shifter in a few days and I thought it might be a good idea to replace the clutch fluid. This is my first manual transmission car
ducq is offline   Reply With Quote
Old 08-27-2010, 08:54 AM   #2
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Yeah, its difficult to access the bleeder (its on the slave cylinder). Most people just replace the fluid in the reservoir, but a lot of the old stuff stays in the line between master and slave.
If you ever drop the transmission, you should install a remote bleeder (a 4-5 foot braided line with bleeder at the end). Then its easy to flush out the old fluid.
Old 08-27-2010, 11:37 AM   #3
ducq
ducq's Avatar
Messing with the slave cylinders or the transmission components is not something I'll mess with. The reservoir is the brake fluid you're talking about right? I read somewhere that they are shared, but someone said if your clutch fluid is dirty or have air bubbles in it, that you can feel it in your shifts. A bit confused by this
Old 08-28-2010, 10:04 PM   #4
Texhawk
Texhawk's Avatar
Drives: 69Camaro,87IROC,96 SS,Z06&Stingray
If the clutch design is similar to the Corvette, you can replace the reservoir fluid, pump the clutch until you see the reservoir fluid turn dark, and replace the fluid again.. repeat the process until the fluid stays clear.
The clutch fluid does circulate enough to refresh it from the reservoir, unlike brake fluid.
If the clutch fluid is dark, it is probably from picking up clutch dust at the slave cylinder, mainly during high rpm shifts where clutch dust fills the clutch housing.
Texhawk is offline   Reply With Quote
Old 08-29-2010, 01:24 AM   #5
BlackM6RS/SS
BlackM6RS/SS's Avatar
Drives: 2010 Black M6 RS/2SS
If you change out the master cylinder/clutch reservoir then you shouldn't have a problem.... like every 2-4K.. its very easy to do if you have a turkey baster and good fluid like ATE Super Blue.
But a Remote Bleeder would be the best option..
10 Blk/Blk RS/2SS w/CGM Stripes
ADM H/C/I M6 480rwhp 435rwtq
FE4 LCAs w/Pfadt ZL swaybars Diff bushings Trailing arms Drop springs
BlackM6RS/SS is offline   Reply With Quote
Old 08-31-2010, 11:13 AM   #6
ducq
ducq's Avatar
Hmmmm can someone post a pic of the clutch reservoir or describe where it's at?
Old 08-31-2010, 02:11 PM   #7
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
The clutch and brake share the same reservoir.
justa25thTA is offline   Reply With Quote
Old 08-31-2010, 02:36 PM   #8
thekid96
Drives: Z06, 69 Camaro
Changing the fluid in the reservoir won't help, all of the effected fluid in the system is below the reservoir in the line and slave cylinder. You need to bleed the fluid from the slave which is a major pain. A remote bleeder is the answer, you can see my solution in this thread:
http://www.camaro5.com/forums/showth...55#post2281955
thekid96 is offline   Reply With Quote
Old 08-31-2010, 08:31 PM   #9
Texhawk
Texhawk's Avatar
I noticed several forum members are installing a separate clutch fluid reservoir like on the Corvettes.
That way, at least the clutch fluid will not also contaminate the brake fluid.
Bleeding the system is the best, but since the clutch fluid circulates itself, unlike brake fluid, you can actually clean the fluid up by just replacing the reservoir fluid and pumping the clutch pedal.
Check this out....
http://www.rangeracceleration.com/Clutch_Care.html
Old 12-17-2013, 08:35 PM   #10
map61968
Drives: 2010 Camaro 2LT RS
Check this out....
map61968 is offline   Reply With Quote
Old 12-24-2013, 08:32 AM   #11
Dfault
Dfault's Avatar
Drives: 2014 Camaro SS
Check this out....
Queen music for;
THE MORE YOU KNOW!!
Dfault is offline   Reply With Quote
Old 12-24-2013, 03:02 PM   #12
Cornflakes'Camaro
Counting down the days...
Cornflakes'Camaro's Avatar
Drives: Black 2011 2SS/RS
OP, Gen5DIY has a kit for this. http://www.gen5diy.com/moar_powa/clutch
I installed it after having my clutch stick to the floor at the drag strip after a few launches. It's cheap, and if you have some mechnical skills you can do the install. Ever since, no sticking clutch during launches.
Tick Performance Custom Cam w/ support mods/BBK LT Headers w/ midpipes/Straight Exhaust/Airaid Cold Air Intake/ZL1 Driveshaft/ZL1 Differential/Hendrix Engineering Offset Bushings/ZL1 Axles/BMR Rear Subframe Bushings/BMR Toe Rods/Carlyle Racing 15" Conversion/Jannetty Winsheild Bottle Scoop/Forgestar 15x10 Beadlocks wrapped in Mickey Thompson Radial Pros
Cornflakes'Camaro is offline   Reply With Quote
Old 12-18-2014, 01:35 AM   #13
bigwillzl1
bigwillzl1's Avatar
Drives: 2013 Zl1
I just changed my fluid by using a turkey baste syringe, works fine for me. Using amsoil dot 4 fluid this time, it has a very high boiling point
Www.lubedealer.com/williamfulton
Www.facebook.com/amsoilunlimited
bigwillzl1 is offline   Reply With Quote
Old 02-24-2015, 10:36 PM   #14
StLCamarofan
Drives: 2020 2SS 1LE M6
Is the above linked procedure by texhawk an option if you have not seperated your reservoirs?
2020 Camaro 2SS 1LE M6 Rally Green
StLCamarofan is offline   Reply With Quote
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 58 12-01-2019 10:54 PM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
Clutch "Sticking" Issue - Not Clutch Dust - Not Boiling Fluid Embalmer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 09-11-2009 10:52 AM
