![]() ![]() ![]() ![]() Drives: '21 Bronco OBX/'18 Jeep GC Altitude Join Date: Jul 2008
How to remove rear side markers?
I finally got my Camaro back from the body shop after being rear ended and it looks like they haven't hooked up my passenger side rear side marker.
I've looked all over, the lighting forum, the DIY forum, but can't find instructions to remove the rear side marker. Found several DIYs for the front ones but nothing for the rear. Any help would be appreciated. I hate seeing a bulb out on my car, makes it look like I don't care about it!
Order Placed: 04/30/22
Order Accepted: 10/18/22 TPW: 11/07/22 Built: 11/18/22 VIN received: 11/19/22 On a Train: 02/27/23 ETA: TBD 2023 Camaro 2SS Convertible/M6/Shadow Grey Metallic/Adrenaline Red Interior/Carbon Flash Wheels/NPP Last edited by CUPRA; 08-30-2010 at 11:18 PM. |
"HILLARY"
I don't know for sure but have heard their is a "secret" way to get to it but now sure how...hopefully someone could help you out...
2010 Camaro SS2 L99 Aircharger, Straightpiped, DT long tubes, Dyno tune by Cal Speed
384 HP & 392 Ft/Lbs. 13.203 @ 107.13 mph at Camaro5FestII |
![]() ![]() Drives: 2006 White Corvette Convertible Join Date: Feb 2010
Shouldn't they fix that?
The Corvette is an animal.
Ok, not to panic, I went out to the garage and had a look at the rear side markers.
Crawled under the car with a flashlight, from behind the rear wheels, perpendicular to the car. If you look between the muffler and the bumper, you can see the clip for the rear side marker waaaaaaay up there. It's a white clip on the edge of the side marker facing towards the front of the car. I was able to get my arm all the way up there and just tip the edge of the clip with my finger... pressed the clip towards the rear of the car, and the side marker just popped right out. It was that easy. Climbed out from under the car, slide the side marker towards the front of the car and it pops right out. Be careful as there is NO slack for the bulb harness at all! I checked the bulb and it had been pushed into the connector too far, so it wasn't making full contact. Adjusted it's position, made sure it was secure and all is now well. All my side markers are working again! Phew!
Order Accepted: 10/18/22 TPW: 11/07/22 Built: 11/18/22 VIN received: 11/19/22 On a Train: 02/27/23 ETA: TBD 2023 Camaro 2SS Convertible/M6/Shadow Grey Metallic/Adrenaline Red Interior/Carbon Flash Wheels/NPP |
| CAMARO WIKI | Tran | Wiki | 67 | 11-27-2024 09:02 AM |
| Help: How to remove side markers | rareslick | Camaro DIY & HOW-TO instructions & discussions | 8 | 04-01-2013 05:18 PM |
| Side Markers? | phenixdragon | Cosmetics and Lighting Modification Discussions | 29 | 08-19-2012 01:01 PM |
| WTB Side markers | christianmotox | Exterior Parts & Accessories | 2 | 06-17-2010 12:01 PM |
| Side Rockers and Rear Fascia Only? | Dr.Bender | Cosmetics and Lighting Modification Discussions | 0 | 06-13-2010 09:10 PM |
