Old 09-03-2010, 01:13 PM   #1
DJJC
Drives: Wanted: 2LT RS Auto
Replacement Tires
I searched but didnt really find what I was looking for... My tires need to be replaced and I am trying to figure out the best option. I dont want to spend money on tires that, like the PZero, wear out so fast.
I have about 34k miles and want to try to get a little more than that out of the next set. Any suggestions? What have you replaced yours with?
Thanks!
JM
Black 2LT RS Auto with Performance exhaust
DJJC is offline   Reply With Quote
Old 09-03-2010, 01:15 PM   #2
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
34K out of pzeros is pretty darn good IMO.....
h2oplay is offline   Reply With Quote
Old 09-03-2010, 01:23 PM   #3
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
You got 34K out of the Pirellis? I'm calling BS.
[B]
Old 09-03-2010, 02:37 PM   #4
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
I've got 25k out of mine but I can just about see above Honest Abe's head now....
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Old 09-03-2010, 02:49 PM   #5
DJJC
Its true guys... not the point of this post, but true none the less...
Now, back to the point. What did you replace them with?
Old 09-03-2010, 03:05 PM   #6
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
You are going to have to go with a tire below the max performance summer tire rating on the P-Zeros if you want them to last longer. There is a trade-off between tire life and sticking to the road. The P-Zeros on my Camaro have plenty of tread left at almost 19k miles, should be able to hit at least 30k before I need to replace them.
The Continental Extreme Contact DWS and Yokohama Parada Spec-X both have a much higher treadwear rating (540 and 420, respectively) than the P-Zeros (220). [Note, you aren't supposed to be able to compare the UTQG rating across brands, only for tires within the same brand.] Both are all season tires instead of summer only tires.
I will say that the Spec-X tires don't seem to be holding up quite as long as I thought they would given their treadwear rating. I've got them on my Expedition and am more than half way through the tread at 20k miles.
rolnslo is offline   Reply With Quote
Old 09-03-2010, 05:42 PM   #7
DJJC
The Continental tires your talking about look good, but they are a lot higher than the others. If they last a lot longer, then it may be worth the expense.
Old 09-03-2010, 08:34 PM   #8
oldfriend
Drives: Fiat 500 E
The UTQG # keep in mind that the higher this # one should expect more road noise and less grabbing to the road !!!!
Old 09-03-2010, 08:36 PM   #9
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
perfect time to upgrade the rims as well(tire/rim package).
Old 09-03-2010, 08:37 PM   #10
ADKINS PERFORMANCE
Banned
Drives: boosting camaro
I get good deals on tires how do you guys like the nitto's
ADKINS PERFORMANCE is offline   Reply With Quote
Old 09-09-2010, 09:09 AM   #11
DJJC
I know there has to be some people that have changed out their tires on here... Come on guys, what did you go with?
Old 09-09-2010, 09:29 AM   #12
MSG'
MSG''s Avatar
Drives: 2010 1SS Camaro
I am interested in the Nitto's, not sure about what the largiest size i can fit on the stock 20in rims, but i want 305s, or 315s on the back if they will fit, my tires have a good 10k left in thread life, and i am at 21k miles
MSG' is offline   Reply With Quote
Old 10-22-2011, 05:22 PM   #13
ramsman34
ramsman34's Avatar
Drives: 2011 Summit White, 2SS/RS-LS3
I just replaced my P Zeros (rear only) with Yoko Paradas. Only been one day but the handling is dramatically different - worse - I will wait to judge them until A. I break them in and B. put Paradas on the fronts as well.
414whp, 403wtq (Mustang Dyno) -Thanks Ray/Full Throttle Kustomz
ramsman34 is offline   Reply With Quote
Old 10-22-2011, 05:30 PM   #14
zogster
Drives: 2014 RRM ZL1 M6
Really not a good idea to put different tires on front/rear.
zogster is offline   Reply With Quote
Cost of Pirelli P Zero replacement tires. myold88 Wheels and Tires Talk Sponsored by The Tire Rack 49 07-26-2014 01:49 PM
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 11:51 AM
New Michelin tires brtaus Wheels and Tires Talk Sponsored by The Tire Rack 8 04-01-2010 02:17 PM
18, 19, & 20" replacement tires ... dougmac Wheels and Tires Talk Sponsored by The Tire Rack 3 03-29-2009 06:27 PM
about all-season tires sting39 Wheels and Tires Talk Sponsored by The Tire Rack 42 01-25-2009 06:37 PM
