Old 09-05-2010, 01:59 AM   #1
Addiction
It's not just a hobby!
Addiction's Avatar
Drives: 2010 2SS/RS
Talking Benefits of 100 octane w/ a tune
Im trying to see if anyone on here would know the benefits of going from a 93 octane gas w/ tune to running 100 octane gas w/ tune? My car is not stock and im shooting to shave some time off my 1/4 time. Im running CAI, LT, Cat back, 3.73, 3200 stal, ported intake and throttle body, and DRs. Im trying to get get a good time on the Bolt-ons w/ out internal fast list.
Addiction is offline   Reply With Quote
Old 09-05-2010, 08:46 AM   #2
Jchaluja
Jchaluja's Avatar
Drives: ZL1 Camaro
run the 100 octane gas from the sunoco gas station here in Jax....w/o tune you'll pick up .1 secs at least, with tune, I imagine that you would pick up more because you can advance timing....it's like running meth...
Jchaluja is offline   Reply With Quote
Old 09-05-2010, 05:03 PM   #3
Addiction
Addiction's Avatar
Drives: 2010 2SS/RS
I have read that running 100 octane on a car tuned for 93 can drop power.
Old 09-05-2010, 05:24 PM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
don't believe everything you hear
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 09-05-2010, 05:32 PM   #5
Jchaluja
Jchaluja's Avatar
Drives: ZL1 Camaro
absolutely not....I am tuned for 93 octane and tun 100 octane at the track all the time and it's always better....
Old 09-05-2010, 10:10 PM   #6
Addiction
Addiction's Avatar
Drives: 2010 2SS/RS
There pump is broke!
Old 09-05-2010, 10:38 PM   #7
paul2010
paul2010's Avatar
Drives: 2012 ZL1 #1278
Mine is tuned for 93/100 mixed and I run 109 when I want to go fast. You don't have to retune to go higher a few points but you would to go lower.
2012 ZL1 #1278
2010 2nd Place Fastest 4 5th Gen LSX Shootout
2011 2nd Place Fastest 4 5th Gen LSX Shootout
paul2010 is offline   Reply With Quote
Old 09-07-2010, 12:08 AM   #8
Addiction
Addiction's Avatar
Drives: 2010 2SS/RS
Ok my car is in the shop they are going to check the power boost from the timing ajustments. Thanks for all the help everyone.
Old 09-07-2010, 02:18 PM   #9
Jchaluja
Jchaluja's Avatar
Drives: ZL1 Camaro
Check with Wells performance, they have mach-series1 accelerator for unleaded fuel, it makes it 100 octane...it works very good, just as good as pumping in 100 octane from the gas station....call them and ask them! 743-5878.
Old 09-07-2010, 04:37 PM   #10
danhr
BAMF SS
danhr's Avatar
I hate these octane booster things. My rule of thumb: The only thing that should go into a fuel tank is fuel.
The highest concentration you can use of mach series accelerator is one can/one gallon of gas (we will assume 93 octane). With the mach accelerator having a rating of 107 and one gallon of 93 octane, you come out with a lil under 100 octane rating fuel. That's roughly 6.50/gallon
I can pick up REAL 100 octane fuel a lot cheaper than that. and not worry about consistency issues of how well my fuel mixed when i add it
Stock Longblock
Old 09-07-2010, 07:00 PM   #11
Addiction
Addiction's Avatar
Drives: 2010 2SS/RS
Thanks bro.
Old 09-07-2010, 11:14 PM   #12
SC2150
You are correct unless it is a high enough compression to make use of it.
The higher the octaine, the slower & more controlled the burn, thus more timing can be added. Unless you are running heads that have raised the CR or are turbo/supercharged.
93 will be where you will make the most power with just bolt-ons.
Old 09-08-2010, 06:03 PM   #13
seanm@stillen
Drives: Grey
Send a message via AIM to seanm@stillen
You can run more advance with 100 octane fuel. More advance = more power if you are knock limited.
If you are not knock limited, then more advance will not really show many gains in power.
Best thing is to try and monitor knock and timing, and see if you need higher octane fuel. Get the car on a dyno, and see what it likes.
seanm@stillen is offline   Reply With Quote
Old 09-08-2010, 09:58 PM   #14
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
Agreed, I lost ET at the track wen I ran out of 93 and ran the tracks 100 octane. I was tuned for 93. I would take that to the bank. Tune it for 100 and you may seem some gain possibly.
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
100 octane, fast list
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 02:41 PM
DO NOT give specific order/vin info on the site if getting a tune! TAG UR IT Tuning / Diagnostics -- engine and transmission 60 07-14-2011 02:47 PM
87 octane, Tune csjcsj 5th Gen Camaro SS LS LT General Discussions 5 04-02-2010 09:56 PM
100 Octane stations in CA 1_2Many Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 58 12-14-2008 02:27 AM
Hmm...higher octane? Shadowsong Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 27 08-29-2008 07:29 AM
