Old 09-08-2010, 06:24 PM   #1
redirish
redirish's Avatar
Drives: 10' IOM 2SS/RS/M6
First time Racing
So I went to Raceway Park in NJ and did some racing. I had a great time and tried some of the tips I read on this thread. I lower my back tire pressure to 25psi. I didn't raise my front tires though. My R/T time looks very slow compare to the other I raced against. How can I improve on the R/T time? Someone told me I should jump on the light before the green lights. I wait until the green, I was afraid to red light lol. I used the launch control and it seems to work pretty good. Check out my time slips and let me know what I can do to improve. Also how do the DA affect my final time? I noticed some time slips that have a slower MPH but a better time. How does that work? Isn't racing awesome
redirish is offline   Reply With Quote
Old 09-08-2010, 06:33 PM   #2
SC2150
Shallow stage (just enough to turn on the second stage bulb) and as soon as the 3rd amber lights hit it. I bet you will be pretty close. Don't worry about redlighting....you just need seat time.
The bulbs have 3 distinct phases each, (LED's not so apparent, but still visable) front (just as the bulb begins to illuminate), top (when the bulb is fully illuminated) and back (as the bulb begins to dim).
When you get used to it you can try to fine tune by where during the illumination you leave. Also, you can bump in deeper during staging, but your ET will be a bit slower. If your going to bracket race you need to understand all about staging & leaving first, and then about driving the finish line.
There is $$ to be made racing brackets!
There is a good group of vette guys up there, introduce yourself and ask for tips.
Old 09-08-2010, 06:41 PM   #3
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Like above, shallow stage, go on last yellow light. Don't worry if you red light, it really means nothing unless you are actually in a real race. Even if you red light you still get all your times. Your ET is the most important stat. Red lighting does not affect your ET.
Old 09-08-2010, 08:26 PM   #4
redirish
redirish's Avatar
Thanks guys! I can't wait to go back to the track to practice!
Vengeance Racing GIVING AWAY $500.00 CASH.. Step inside for details!!! Ron@Vengeance Engine Internals 4 08-24-2010 07:47 AM
Vengeance Racing GIVING AWAY $500.00 CASH.. Step inside for details!!! Ron@Vengeance V8 Bolt-Ons & Tunes 0 08-10-2010 10:31 AM
Got Pulled over... TRSS2 Cosmetics and Lighting Modification Discussions 39 03-08-2010 12:57 PM
MTI Racing 500ci Dominator Engine Assembly MTI Racing 4th Generation Camaros 1 08-27-2009 12:00 PM
