![]() ![]() ![]() ![]() Drives: 2010 IOM SS Join Date: Aug 2009
Cold Air Intake & Maf Scaling
Just trying to understand what is going on from the following 2 scenarios. Complete Novice
Intake 1. Wot Maf frequency scales to 8990--- Maf g/s is 344 Intake 2. Wot Maf frequency scales to 8465--- Maf g/s is 344 Intake 2 has a larger tube. If intake 2 was scaling higher would the maf g/s also be higher? Does this translate into more power? |
Drives: 2006 Corvette Z06 Join Date: Feb 2010
Your MAF spits out a frequency based on how much air is moving over it. When you tune, you are defining what airflow value is at each frequency.
If Intake 2 is showing the same airflow at a lower frequency... then yes, if you're able to hit the same frequency as Intake 1, you are moving more airflow. Your engine is an airpump. The more air you can pump through, the more power you're going to make. When a car is tuned the proper way, you can get pretty close estimates by reading how much air is moving through. A rough estimate is that each lb/min of airflow translates to about 8.5 wheel horsepower. If you're reading g/sec, then multiply g/sec by 1.1 for an estimate. |
#3 | |
This was exactly what I was looking for. Thank You DSteck. I will look into having the maf scale redone. Car runs good but hate to leave something on the table. |
If fueling is correct at WOT, then precisely calibrating the MAF won't really pick up power. It will just make things smoother and more predictable.
| Pipeline True Cold Air Intake for Sale!!! Shipping Included!! | se7en | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 20 | 01-14-2011 02:05 PM |
| Cold Air Intakes 2010 Camaro Blowout! K&N | AIRAID | SLP | Best Price Guaranteed! PM | AutoAgenda | V8 Bolt-Ons & Tunes | 47 | 01-12-2011 01:35 PM |
| Roto-Fab Cold Air Intake from Phastek Performance | Sean@Phastek | V8 Bolt-Ons & Tunes | 17 | 06-09-2010 01:31 PM |
| Saturn Sky Red Line GMPP cold air intake question | 496BIGBLOCK | General Automotive + Other Cars Discussion | 8 | 12-29-2008 02:50 AM |
