![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro LS V6 Join Date: Jul 2010
2010 LS camaro rim fitment
i keep reading and searching and everybody kinda talks about the rs and ss as far as getting new rims on them and the size of tires and rims and offset on only the rs and ss! i need some expertise on the ls. i dont have big calipers so im assuming i do not need a special rim to compensate for such a big caliper
i was told these will fit the camaro ls. i dont know if there trying to sell me and just say it fits but i have asked numerous rims vendors and they have stated the rims will fit. 1st rim is avenue a605 22X9.5 bolt pattern 5x120 offset 35 2nd rim is forte f3 22x9.5 bolt patter 5x120.65 offset 35 3rd rims is forte f10 22x8.5 bolt pattern 5x120 offset 35 4th rim is forte 42 is 22x8.5 bolt pattern 5x120.65 offset 35. 5th rim is avenue a604 22.x8.5 bolt pattern 5x120 offset 38 from what i was told this .65 will not matter in fitting it on my car and that the 5 lug drill hole is slightly bigger than a normal 5x120! my thing is will this actually fit(the 120.65 bolt pattern) and what size tire would i get? soooo what actual offsets will work for my car. i was looking at 265/30/r22 OR the 285/30/r22. help me peoples. plus i would get all the mirrored/gray part painted white to match my white ls. |
Drives: 2010 Camaro 2SS/RS 6MT Join Date: Apr 2010
Can someone answer? lol
well damn!
![]() Drives: 2010, 2000, 1971 Camaros Join Date: May 2010
I can tell you that the 120.65 will fit as I put one from my 4th gen just to see, though I still would not recommend running it. They should have the correct bolt pattern for your application or choose another vendor. I have an 1LS as well. Pretty much anything that will fit on Ss or LT Camaro's will fit the 1LS. My car came stock with the 21 inch wheel option. I just changed to Forgelines, 20x 9.5 and 20x11 with 275 up front and 315 in back. No idea about 22's. Good vendors should be able to provide you with all this info.
![]() Drives: SIM 2010 Camaro LT1 Join Date: May 2010
Anything that will fit on an SS will fit on an LS or an LT. I have an LT and put big wheels and tires on mine. The bolt pattern, wheel well etc will be the same. The only real difference is that you actually have more options than an ss as you dont have stupid huge calipers and as such have a larger offset range.
SIM 2010 Camaro 1LT
25% window tint, Interior LED kit, HIDs (non RS), CGM bowties, Custom exhaust, 20" Axis Zeros riding on Pirelli Zero Scorpion tires Gloss black bumble bee stripes, Injen short ram intake. More mods to come! ![]() |
| New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! | RPI Designs | Exterior Parts & Accessories | 30 | 02-20-2013 03:23 PM |
| GM unveils Jay Leno Camaro, Camaro Synergy, Camaro Chroma, Camaro Dusk at SEMA | irocnroll | 5th Gen Camaro SS LS LT General Discussions | 101 | 02-27-2012 12:25 PM |
