Old 09-09-2010, 09:30 PM   #1
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
Vararam Tune Only Model - My Review
Well, I did a lot of my raving in the SLP Loudmouth review here..http://www.camaro5.com/forums/showthread.php?t=102886
I wanted to give Vararam a fair review of their own. Even though I didn't by it from Vararam directly (thanks LS3SSRS).
I was skeptical at best since I saw so many for sale on here. BUT, I took the plunge anyway...
I posted all the Dyno results in the thread above reviewing the SLP's.
The ONLY thing I didn't like about the Vararam, is that the radiator doesn't fit as tight as I would like. It isn't going to go anywhere, but just doesn't seem "right". I am trying to figure out a way to secure it back in the original screw holes....not any time soon, but am pondering it......I just wish the radiator was tighter.
All in all, great performance increase (better than any other CAI) and good instructions, easy to install.
**edit** I found out why my radiator didn't fit as tight. The guy I bought it from didn't send the bolts or installation instructions on how to alter the existing radiator mounts and then turn them around and use the longer bolts to secure the radiator.
TLSTWIN is offline   Reply With Quote
Old 09-09-2010, 09:52 PM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
You can do what i did for the radiator, But its a lot of work, I made filler parts that go in from the front, There 1/16 aluminum that i had bent 1" wide flange for the radiator to sit on and that way it also closes the side so no air gos around the radiator.
I like it and it work good for me.
Old 09-09-2010, 09:59 PM   #3
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Got any pics? I am a visual kinda guy
Old 09-09-2010, 11:30 PM   #4
2SSRS@Gen5diy
I will get you some, but you do need to remove the front bumper cover to do that Mod.
Old 09-09-2010, 11:52 PM   #5
themossman
Apprehensive Optimist
themossman's Avatar
Drives: '10 SS/RS SIM
I used the radiator bolts that Vararam provided and cut off the little tabs on the stock radiator mounting blocks...it got it all snug and tight as stock...
Car is for sale --->http://www.camaro5.com/forums/showthread.php?t=158486
Current Summary:
Engine:Phase One-(All work by Vengeance Racing): Custom Cam, AR Headers, ported throttle body, ported intake, custom tune, dual valve springs, hardened push rods, under drive pulley, thermostat, Vararam CAI, C5R timing chain, Melling oil pump catch can, breather, MagnaFlow Sport Axle Back
Suspension: Pfadt Sport Sway Bars, Pfadt drop springs
Other: MGW Shifter, Custom Paint
my build journal ---->http://camaro5.com/forums/showthread.php?t=30057
themossman is offline   Reply With Quote
Old 09-10-2010, 07:14 AM   #6
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
That cool, sounds like a winter project...
Can you take a picture of those. I don't think I recieved those.....guess that is because I didn't buy from Vararam, but they weren't in the instructions though either, so maybe they changed things
Old 09-10-2010, 08:01 AM   #7
RobertHarriSS
RobertHarriSS's Avatar
Drives: 2SS/RS M6
If you didn't get the bolts from Vararam, you can buy some from a hardware store (about 4"-5" long). All you need to do is trim the tabs off the top of the radiator where the stock mounting blocks go, turn the mounting blocks 180 deg. and use the new longer bolts to attach the blocks to the original holes. As you tighten the bolts the radiator will suck up nice and tight.
RobertHarriSS is offline   Reply With Quote
Old 09-10-2010, 12:10 PM   #8
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
I hate to ask this, could you post up a picture or two, or send them to me?
I kinda need to see it... sorry
Old 09-10-2010, 02:02 PM   #9
RobertHarriSS
Drives: 2SS/RS M6
Sure. I'll post them here when I get home. It'll be about 6 or 7 your time.
Old 09-11-2010, 06:55 AM   #10
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
So going back to the dyno.
From what I could see, you picked up about 17 rwhp (no tune) and 21 rwhp (with tune) with the Vararam intake.
As mentioned, you should call Vararam and have them send you the bolts you need. Or just go to a local hardware store. Do get the bolts to fit right you'll need to shave the little plastic tabs on the radiator.
Without the bolts, the radiator will move back and forth (not good).
Old 09-11-2010, 09:13 AM   #11
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Close, it was more like 18, 19 when the first 3 are averaged (374.21HP), an then the first pull with the Vararam (393.29), that is 19.08 HP. Then with the tune it put it at 397.56WRHP.
There were a few pulls with the Vararam on, but I was too busy watching instead of filming and taking pictures to document. they were all pretty much the same.
ya, my radiator is fairly secure as is, but would prefer the bolts and firm position. I will go to my local hardware store once I see how they are secured (pics).....
Old 09-11-2010, 10:51 AM   #12
RobertHarriSS
Drives: 2SS/RS M6
The bolt is 5" long. Just trim off the tab that's on the radiator and turn the mounting block around and insert longer bolt.
Old 09-11-2010, 11:50 AM   #13
SGOS252382
SGOS252382's Avatar
Nice numbers
I'm a little suprised you only picked up 4.27 rwhp from a tune. My thinking would be that the Vararam was already making you lean, so there wasn't a lot of rwhp to gain from the tune (just getting everything set A/F where it needs to be).
Old 09-11-2010, 12:52 PM   #14
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Nice numbers
yep, the tune was basically for idle and A/F mixture
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 02:41 PM
Drawbacks to a mail order tune herkman Tuning / Diagnostics -- engine and transmission 24 05-28-2010 06:27 AM
Lets play a game 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 56 09-26-2009 10:08 AM
