Old 09-10-2010, 09:09 AM   #1
Isshinryu
Isshinryu's Avatar
Drives: 2010 Camaro SS/RS yellow/black
LS3 Coolant Temperature Fault
Has anyone experienced a "Coolant Temperature is 185 degrees" pop up on the DIC while driving? Twice now I've had this show up while cruising and the only way to clear it is to turn car off. Both times the heat had been on. Took to dealership but no fault codes showed up and no service bulletins. Have to wait till I get the fault again and drive it to dealership.
Isshinryu is offline   Reply With Quote
Old 09-10-2010, 09:58 AM   #2
wirebender
wirebender's Avatar
Drives: 2017 ZL1, A10, White, sunroof, nav
Not that, but this AM mine (L99) said AC off due to high engine heat.....after sitting all night....and the temp guage was not registering at all....(even after driving to an appt. and back)...oil & trans temp is good. Then when I started it again after getting home & turning it off for just a minute, it was, well, a "difficult" or "laborious" start. Any ideas???? Bad engine temp sensor screwing with the ECM maybe??? Can't get it in @ dealership till like Tues.....
wirebender is offline   Reply With Quote
Old 09-10-2010, 08:17 PM   #3
wirebender
wirebender's Avatar
Try this....worked for me....so far!
On advice forom a trusted associate, I disconnected the neg. battery cable for 10-15 min. to "reset" the system and it seems to have worked! The temp gage is registering again, no DIC msg...all seems fine for now after a good 20-30 mi. drive on errands!!! Kinda like a windows os reboot!!! Hope it lasts!
Old 09-11-2010, 11:26 AM   #4
Isshinryu
Isshinryu's Avatar
Yea I've had no issues starting and dealership found no codes. I put the roto fab cai on also but can't see how that would cause this. I'll wait a bit and try the battery cable but I had it off when I put the cai off. Its only happened twice. Thanks for the feedback.
Coolant smell on LS3 with Maggie? BlownSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 04-20-2010 11:56 AM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 11:06 AM
